Synethetic or Conventional OIL?!?!?
Old Jul 5, 2004 | 12:19 PM
jbsmith's Avatar
Default Synethetic or Conventional OIL?!?!?
What kind/brand oil do you run. I have heard all this hype about synethetics but am tough to switch. what are your opinions.
Old Jul 5, 2004 | 12:30 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Synethetic or Conventional OIL?!?!? (jbsmith)
Stay with regular motor oil if you're not already synthetic.
I think synthetic is overrated.
I have 3 Honda hybrids. One runs Mobil 1 5W30, the other two run conventional oil. I don't see the difference in the way each runs or in terms of how the oil looks when changing the oil.
Hell the only reason I even run the Mobil 1 in the one swap is because the former owner of the car (a Type R) ran it religiously.
Old Jul 6, 2004 | 02:21 PM
ejprimo's Avatar
Default Re: Synethetic or Conventional OIL?!?!? (B18C5-EH2)
id say run a high mileage oil rather than a regular conventional. its not that much more $$ than dino oil. it also outperforms conventional oil in many aspects. its not an energy conserving oil because its has a thicker viscosity than regular dino of the same grade.
Old Jul 6, 2004 | 02:41 PM
suspendedHatch's Avatar
Default Re: Synethetic or Conventional OIL?!?!? (ejprimo)
If your engine is low mileage without any oil leaks and doesn't burn oil, then you can run synthetic. You can get the big jugs of it at a large supermarket and save some money over the little jugs. It's still not very bang for your buck, but it's worth the money.
Old Jul 6, 2004 | 03:15 PM
stockegsix's Avatar
4.2 quarts
5w30 mobil 1 full syn. $4.99 a quart
oem honda oil filter $7.50
oem honda washer.75cents
i spend about $35 buck every 2500-3000 miles on oil change. plus I do it myself
Old Jul 6, 2004 | 03:34 PM
pancake56's Avatar
use synthetics only if you have turbo. otherwise, quakerstate it.
Old Jul 6, 2004 | 03:46 PM
jeffk182's Avatar
No need to run synthetic oil..conventional oil is just as clean.
Old Jul 6, 2004 | 04:39 PM
dantastic's Avatar
synthetic oils have scientifically proven advantages to conventional oil. it also last much longer then conventional oil. many bmws and benzes can go 10kmi+ on synthetic oil, using their computer calculated service intervals. i go the factory reccomended 7500mi between oil changes with mobil1
Old Jul 6, 2004 | 04:44 PM
adnoh's Avatar
Default Re: (jeffk182)
d16z6 w/ 240k miles. Used M1 since the day I bought it.
Doesn't burn any oil, and Internals are super clean.
FitsMe
Honda Fit
Apr 16, 2012 05:05 AM
"Ridge"Racer
Honda Civic (2006 - 2015)
Aug 8, 2007 05:22 PM
ironballz
May 13, 2004 02:38 PM
HybridHatch
May 26, 2002 10:16 AM
tensai717
Dec 9, 2001 03:49 PM
