Greddy Turbo Timer Harness
Old Jul 5, 2004 | 07:41 AM
phreakmang's Avatar
Default Greddy Turbo Timer Harness
Looking for a greddy turbo timer harness.
Anyone hook me up with a site that sells these?
Old Jul 5, 2004 | 07:46 AM
Bruce Leeroy's Avatar
Default Re: Greddy Turbo Timer Harness (phreakmang)
www-sp-power.com
Old Jul 5, 2004 | 08:01 AM
phreakmang's Avatar
no civic harness there mang.
Old Jul 5, 2004 | 09:48 AM
phreakmang's Avatar
Old Jul 5, 2004 | 09:56 AM
Kamin's Avatar
there wont be one for a civic.
why would honda make a harness plug in for a turbo timer when none of the civics EVER are turbo from the factory?
you are gonna have to wire it yourself.
Old Jul 5, 2004 | 10:04 AM
phreakmang's Avatar
Default Re: Greddy Turbo Timer Harness (Kamin)
I thought greddy made a harness that plugged into the civic factory harness.
Perhaps I was told wrong
Old Jul 5, 2004 | 10:12 AM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phreakmang &raquo;</TD></TR><TR><TD CLASS="quote">I thought greddy made a harness that plugged into the civic factory harness.
Perhaps I was told wrong</TD></TR></TABLE>
well the way the other harness' for the turbo timers work, the factory has a plug that is hanging off the main ignition harness that is set up for a TT.
ive never seen or heard of one for a civic.
Old Jul 5, 2004 | 11:46 AM
phreakmang's Avatar
online wiring diagram perhaps?
Old Jul 7, 2004 | 11:56 PM
woops, didn't know it was for a civic, but we do carry greddy harness.
Old Jul 8, 2004 | 05:29 AM
boostin4drcivic's Avatar
Default Re: Greddy Turbo Timer Harness (delslow_SP)
u have to hard wire it. nobody sells a harness for a civic since they were never turbo from the factory. its not hard at all. all u need to do, is take of the panelling under the steering wheel around the iginiton. under and to the left there are some fat wires there. those are the ones you will tap into. all u need is a test light and check the wires in the on and off key positions. you will find which wires are which. shouldnt take u more than 5 mins to figure out the wiring, then another 10 or so to solder all the connections. good luck
Old Jul 8, 2004 | 07:23 AM
phreakmang's Avatar
Easy enough, although we found out low temp solder does not stick to the old terminals very good. It just balled up and stayed on the iron.
Gonna pick up some silver solder this afternoon and finish it up.
Turbo_Mike
Aug 11, 2005 10:22 AM
boostedblack99
Jul 13, 2005 07:23 AM
