Datalogging hardware.
I'm sure most places that sell "data acquisition" equipment will have the sensors you're looking for, to compliment their datalogger product.
Such as: http://www.race-technology.com....html
From Pi Research -- http://www.piresearch.com/products.cfm
Ahhh ... found some actual parts (not cheap):
http://www.advantagemotorsports.com/Sensors.htm
Modified by zygspeed at 1:53 AM 7/5/2004
radio shack will have a linear pot. it will depend on how you will wire it to get it to work properly. i didnt get a chance to fully play around with the datalogger i had setup, but it seemed to work fine, until something happened with the wiring i didnt fix and havent bothered with since.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">
I'm thinking about selling my DL90 setup - IM me for details if interested.
Good Deals, don't know if it's exactly what you're looking for though.
http://www.allelectronics.com/...store
The trick, I believe, is to get a regular pot and rig up a rack and pinion type machanism to move with the pedal or whatever you're tracking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eliktronik »</TD></TR><TR><TD CLASS="quote">The trick, I believe, is to get a regular pot and rig up a rack and pinion type machanism to move with the pedal or whatever you're tracking.</TD></TR></TABLE>
Yes, I believe this is what he was getting at. Because a linear pot itself is not an unusal item. I might consider looking into DIY robotics catalogs to source these.
-PHiZ
-PHiZ
http://www.omega.com
Edit: they may not have pots (I have been looking there for thermocouples), but their stuff is WAY better than the "automotive grade" crap, which apparently is just that...crap.
Take a "regular" reasonable precision pot, spring load it towards one stop, put a spool on the shaft with a known diameter, thread a thin aircraft type stainless steel cable of 1/16 inch diameter on the spool, and wala..... you have a "digital pot". These can often be installed more easily than a 4" linear pot.
Monochild
13
May 21, 2005 10:53 AM
