Brakes
Old Jul 4, 2004 | 05:34 PM
blueskiesfade609's Avatar
Default Brakes
im taking disc brakes off of a g2 intega front and back. anyone have a link with some info on how to do the back ??? thanks
Old Jul 4, 2004 | 06:57 PM
scorched0's Avatar
Default Re: Brakes (blueskiesfade609)
how to take them off? Shouldn't be too hard....or do you mean how to adapt them to the ef?
Old Jul 4, 2004 | 07:14 PM
Default Re: Brakes (scorched0)
yeah,... how to swap all the **** over to convert it from drum to rotors. cause im really not understanding this 40/40 purge valve with the flux compasitor that amps up your googleplexor 12xs its normal ratio,... jk but on a serious note i dont understand all that work that is involved if you got a link or something with pics on how to do it or just know how to do it let me know. thanks
Old Jul 4, 2004 | 07:22 PM
scorched0's Avatar
check out http://www.crxsi.com Should have everything you need.
Old Jul 4, 2004 | 07:33 PM
EF9Si-T's Avatar
I saw nothing informational there, other than the fact that they are prototyping the new possibly to come CRX.
Old Jul 4, 2004 | 08:15 PM
crxgator's Avatar
Default Re: Brakes (BUG_MANIAC)
i just did the fronts today...bolted right up...
Old Jul 4, 2004 | 09:14 PM
mr. carpenter's Avatar
Default Re: Brakes (crxgator)
i think there is a good brake upgrade swap write up in the FAQ at the top of this forum.
Old Jul 4, 2004 | 11:21 PM
eda6's Avatar
Use existing compensator arms.
Everthing else bolts up.
If it's an 88 use 88 lca's.
If it's a hatch the ebrake cables fit perfectly.
From reading recent threads I hear the ebrake cable is too long for a crx.
Get 4040 prop. valve.
Get 90-93 integra non abs booster/mc.
That's everything you need to know about the parts.
Old Jul 5, 2004 | 06:37 AM
90Zcrx's Avatar
Default Re: Brakes (eda6 hb)
Hey I have an 88 and I don't get what you mean by "if it's an 88 use 88 lca's", does that mean in the rear I can keep my 88 LCAs? I always assumed I would have to swap out to 89+ LCAs (not that this is a bad thing, hunting for good struts sucks).
Old Jul 5, 2004 | 06:39 AM
crx_88_si's Avatar
http://www.homemadeturbo.com/f...15507
enjoy.
Old Jul 5, 2004 | 08:29 AM
eda6's Avatar
Default Re: Brakes (90Zcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90Zcrx &raquo;</TD></TR><TR><TD CLASS="quote">Hey I have an 88 and I don't get what you mean by "if it's an 88 use 88 lca's", does that mean in the rear I can keep my 88 LCAs? I always assumed I would have to swap out to 89+ LCAs (not that this is a bad thing, hunting for good struts sucks).</TD></TR></TABLE>
You're gonna have to keep the 88 lcas until you buy new struts.
Your rear struts will not bolt to the Integra lca.
You're going to need 89-91 civic/90-93 integra rear struts to use the teg lcas.
Until you buy new struts, use the 88 lcas.
I agree 89-91 lca's are the way to go for a better suspension.
I had to figure this out on my own.
I didn't know about h-t at that time.
descartesfool
Sep 11, 2011 11:54 AM
deadmonday08
Honda Civic (2001 - 2005)
Nov 3, 2010 08:43 PM
EG BEAST
22
Oct 23, 2009 02:25 PM
RB_EJ8
10
Aug 24, 2008 10:41 PM
