is the ecu screwed up??
I have a 98 civic with a built up 95 1.6 sohc vetch with a drag 3 turbo kit. I accidently rewired my o2 sensor wrong. I hooked up the signal wire and the heater wire up backwards. Now i get a check engins light on where i did not before. I hooked them beck up the way the were but no difference. Is it possible that i have screwed up my ecu?? please help
jump your ECU to find out what codes it's throwing...
jump your ECU, put your ingnition in "on" position
check engine light should light up and would start to throw a code...during this process, if the check engine light stayed lit, you have a code 0 which means your ECU went kaputz....
hope this helps...
hope this helps...
Mesm23
Jun 13, 2017 09:11 AM
1320king
Jul 22, 2007 12:32 PM
frostt3ch
10
Jun 22, 2003 11:09 AM
