Where is the 'right brake light sensor'?
Old Jul 4, 2004 | 02:04 PM
gofastant's Avatar
Default Where is the 'right brake light sensor'?
For some reason, my rear right brake lights wont come on. Sometimes the rear center brake like wont come on either. And other times the right back up light wont come on. I've studied the schematics and it looks like the rear right brake light sensor is probably bad. Anyone know where it is?
thanks a ton.
Old Jul 4, 2004 | 04:28 PM
jlv55's Avatar
Default Re: Where is the 'right brake light sensor'? (gofastant)
are you sure its not the bulbs? the switch that sets off the brake lights is on your brake pedal bracket, but it wouldnt make sense for that to stop working only on one side. check the bulbs.
Old Jul 4, 2004 | 06:45 PM
93CivicDxer's Avatar
Default Re: Where is the 'right brake light sensor'? (klutch44)
ya check the light bulb
Old Jul 6, 2004 | 09:46 AM
gofastant's Avatar
Default Re: Where is the 'right brake light sensor'? (AcCoRdInGtO_91)
Definately not they're bulbs. I creplaced them and they're good. As is all fuses related to the tail lights.
Old Jul 10, 2004 | 05:53 PM
gofastant's Avatar
I still need to know.
Old Oct 9, 2004 | 01:27 PM
truong88's Avatar
It is locate next to the light socket in the trunk. It is a 2"x2" box with a wire plug at the end.
Old Nov 5, 2015 | 05:06 PM
BryanO's Avatar
I have the same problem, new lights, good fuse, even checked the switch only thing I can think of is the sensor.
Old Nov 5, 2015 | 06:55 PM
BryanO's Avatar
There should be a connector by the sensor, connects fuse to sensor and sensor to high center light
Tech-Nics
Nov 1, 2022 07:06 PM
88accord
Mar 24, 2018 09:29 PM
deadcylon
Acura TL, RL & ZDX
Jul 27, 2016 03:14 PM
nicolaselias
Dec 22, 2011 03:58 PM
dannyboyindc
Feb 24, 2010 12:36 PM
