Vibration in Steering Wheel at High Speed
Old Nov 19, 2001 | 09:02 PM
gina's Avatar
New User
Default Vibration in Steering Wheel at High Speed
Hey guys.... I was driving my R over the weekend on the highway and noticed at about 80-90mph my steering wheel is shaking and vibrating unusually. Any ideas of what this could be? I am very low on cash and I dont want to take it to the shop if it is something simple. Any ideas? Thanks in advance for your help !!!!
Old Nov 19, 2001 | 09:07 PM
CW_97_ITR's Avatar
Default Re: Vibration in Steering Wheel at High Speed (00 Type R Chick)
Try checking your tire pressures and see if there is anthing stuck inthe tread of your tires (screw, rocks).
Have you hit any pot holes, or anything else hard with the front wheels? I have heard that the ITR front end can come out of alignment real easy.
Also check your tire wear and dents in your rims.
Hope this helps. good luck!
Old Nov 19, 2001 | 09:11 PM
Akira-R's Avatar
Default Re: Vibration in Steering Wheel at High Speed (CW_97_ITR_071)
Your wheels may need to be balanced again.
Check to see if the weights fell off or something.
--reid
Old Nov 19, 2001 | 11:04 PM
tjtruong's Avatar
New User
Default Re: Vibration in Steering Wheel at High Speed (Akira-R)
--reid
Thats the first thing that came to my mind..
try that before anything else....thats most likely the problem.
Old Nov 19, 2001 | 11:13 PM
B2FiNiTY's Avatar
Your tire probably needs to be balanced.
Old Nov 19, 2001 | 11:17 PM
kitkatR's Avatar
Default Re: Vibration in Steering Wheel at High Speed (B2FiNiTY)
That happens to me but vary little vibration and it is around the 135 to 150 range.
Old Nov 20, 2001 | 02:35 AM
arren123's Avatar
It happens to me too when I rotate the back set of tires to the front.. i think I just have a bum tire because I got the wheels rebalanced and they said it was dead on.
Old Nov 20, 2001 | 04:33 AM
ZygSpeed's Avatar
Default Re: Vibration in Steering Wheel at High Speed (arren123)
Other than rebalancing (which is/was) my guess as well -- try taking the wheel off and then carefully (evenly) re-tightening the lug nuts. This helped me last time, since those jack-offs at NTB don't know how to use anything but air tools! HTH /ed
Old Nov 20, 2001 | 04:36 AM
Back in Black's Avatar
Rather OG
If you're car is lowered and the camber isn't adjusted properly, your front tires are more than likely warped towards the inside. If not, my bet is on the need for balancing
W00tn
Honda Civic (2001 - 2005)
10
Jun 18, 2006 03:24 PM
h22pwr
Apr 12, 2006 06:46 AM
canadianSIR-G
Nov 9, 2005 10:27 PM
Nizzy
Aug 21, 2003 07:31 AM
