starter trouble?
Old Jul 4, 2004 | 12:23 AM
Mjfan12's Avatar
Default starter trouble?
my friends car won't start. he has a 95 civic. We bought a new battery and that didn't solve the problem. All the electronics work, and everything. it's just when you turn the key nothing happens. yesterday we tried to jump the car, and it was trying to crank. We must have done it too much because now that doesn't even happen. All we hear is a slight humming noise.
sp is this a bad starter? how much does one cost? I hear a rebuilt one is around $100. how much would labor be if it's taken to a decent shop? also while he's doing that, he want's to switch the alternator. how much does one of those cost? thanks
Old Jul 4, 2004 | 12:24 AM
accordnut's Avatar
Default Re: starter trouble? (Mjfan12)
Check the ground wire.
Old Jul 4, 2004 | 12:28 AM
Mjfan12's Avatar
Default Re: starter trouble? (accordnut)
yes, I do remember seeing a loose black wire in the engine bay, I don't remember where it lead to though. where would I connect it to? the engine or chassis?
Old Jul 4, 2004 | 07:18 AM
Mjfan12's Avatar
bump
Old Jul 4, 2004 | 07:57 AM
hondaciv3's Avatar
on that last question, trace the wire back to where it comes from if it is a ground wire and is hooked to the motor ground it to the frame. if it is just connect to the frame then find its correct spot. if it isn't either of those that might be your problem, find out what it is.
Old Jul 4, 2004 | 03:24 PM
Mjfan12's Avatar
another question. if a car has a turbo timer, that is connected into the ignition system right? what if it was removed and the stock harnesses weren't plugged back in, then the car wouldn't also start. right?
Pagley
Sep 4, 2010 12:05 PM
JDM C.A.R
May 9, 2010 04:38 PM
92hondalude
Jul 14, 2009 08:29 PM
LsScivic
Mar 4, 2009 07:39 PM
Skeletor
13
Nov 22, 2005 11:03 AM
