JDM cluster+ stock cluster??
Old Jul 3, 2004 | 08:32 PM
crexer's Avatar
Default JDM cluster+ stock cluster??
I have a spare jdm cluster laying around and it is missing the plug ins for the harness so it is basically useless. My question is do you guys think I could take the tach that redlines at 8k out of the jdm cluster and put it into my dx cluster? Dont I need an electronic speed sensor? what do you guys think about this?
Old Jul 3, 2004 | 11:58 PM
rjay8604's Avatar
Default Re: JDM cluster+ stock cluster?? (crexer)
well, i was able to put a jdm DA teg tach into a usdm DA teg cluster, it all worked, all the screws and evrything were the exact same, i really think that would work, because the vss is for the speedo only. well good luck keep the forum update when your done.
Old Jul 4, 2004 | 08:36 AM
crexer's Avatar
Default Re: JDM cluster+ stock cluster?? (rjay8604)
can you tell me more about the vss? dont I need an electric one from a del sol?
Old Jul 4, 2004 | 12:26 PM
crexer's Avatar
to anyone that might care or be halfway interested, the jdm tach does not work in a usdm cluster. Bolt patterns are different and the shape of the gauge is different. Im sure you could make it work somehow but i just dont think its worth it.
Old Jul 4, 2004 | 01:26 PM
JohnnieChimpo's Avatar
Good info, I was wondering that myself.
If you have no use for the JDM cluster and want to sell it let me know.
Old Jul 5, 2004 | 09:01 AM
rjay8604's Avatar
Default Re: JDM cluster+ stock cluster?? (JohnnieChimpo)
Well, if you decide to put the jdm cluster in, i do have a vss i can sell to you, it's from the jdm b16a with y1 tranny so its the one that came on the sir. good luck.
Old Jul 5, 2004 | 09:14 AM
crx_88_si's Avatar
what year usdm cluster did u attempt this on?
Old Jul 5, 2004 | 11:47 AM
crexer's Avatar
Default Re: (crx_88_si)
I tried it on a 89 dx cluster. The 90-91 cluster might be able to accept the jdm tach...i didnt think about that
Old Jul 6, 2004 | 08:20 AM
Default Re: (crexer)
Isn't the tach's face too small to fill the hole in the non JDM cluster?
That's what it looks like when I compare pictures.
I'm still interested in it.
8bluddyknuklz
Jan 25, 2010 12:30 PM
generation_D
Aug 16, 2009 08:36 AM
2-7offsuit
15
Aug 13, 2005 10:43 AM
95dxhatch
28
Oct 8, 2004 08:28 AM
Filliam H. Muffman
Jan 14, 2004 05:32 PM
