Where To Get THis Kind Of Heat Wrap? W/PIC!!!
Old Jul 3, 2004 | 05:00 AM
integlspwr2k's Avatar
Default Where To Get THis Kind Of Heat Wrap? W/PIC!!!
Im talking about the orange thing that is wraped around the the extra crank case breather right above the manifold.
Anyone know whats it called and where I can get some.
Thanks!
Old Jul 3, 2004 | 05:02 AM
boywonda's Avatar
Default Re: Where To Get THis Kind Of Heat Wrap? W/PIC!!! (integlspwr2k)
damn, I wanna know too
Old Jul 3, 2004 | 05:59 AM
b18cls1's Avatar
Default Re: Where To Get THis Kind Of Heat Wrap? W/PIC!!! (boywonda)
any aeroquip or parker dealer should be able to get it they both have thier own version of it.
its fire sleeve
Old Jul 3, 2004 | 07:52 AM
stinker504's Avatar
I picked mine up at a local hydrolics place.
Old Jul 3, 2004 | 07:55 AM
IN VTEC's Avatar
http://www.racerpartswholesale.com
I get my Firesleeve from them since they're local with some of the best Aeroquip pricing I've seen thus far. Summit can probably also get it too if you look it up by part number or call them with a part number and description.
Old Jul 3, 2004 | 04:41 PM
Boofster's Avatar
Default Re: Where To Get THis Kind Of Heat Wrap? W/PIC!!! (IN VTEC)
Whoa nice engine bay! Got any more/bigger pics? What manifold is that?
Also is that thermal insulation or just "fire proofing"?
Old Jul 3, 2004 | 05:31 PM
IN VTEC's Avatar
Default Re: Where To Get THis Kind Of Heat Wrap? W/PIC!!! (Boofster)
It's a thermal insulator/deterrent. The outer sleeve is high temp silicone and the inner part is a fiberglass weave.
It's also not fire proof. It's fire retardent.
I've used it on a turbo oil feed line that sits an inch from the manifold and it has yet to deteriorate or harden from the heat after 6 months.
Old Jul 3, 2004 | 05:41 PM
integra-modder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">It's a thermal insulator/deterrent. The outer sleeve is high temp silicone and the inner part is a fiberglass weave.
I've used it on a turbo oil feed line that sits an inch from the manifold and it has yet to deteriorate or harden from the heat after 6 months.</TD></TR></TABLE>
I gues this stuff is pretty good then. I need to get some for my oil return since thats about 1 inch from my DP.
Old Jul 3, 2004 | 06:49 PM
MooreBoost's Avatar
Default Re: Where To Get THis Kind Of Heat Wrap? W/PIC!!! (integra-modder)
What is the purpose of those two lines feeding off the valve cover?
Old Jul 3, 2004 | 07:34 PM
beepy's Avatar
Default Re: Where To Get THis Kind Of Heat Wrap? W/PIC!!! (tegunderpressure)
Looks like a Negative Crankcase Ventilation (NCV) system. Uses the scavenging effect from the exhaust to vent the crankcase instead of using engine vacuum.
I could be wrong, though, but this sort of system has been used by V-8 guys for many years.
Old Jul 3, 2004 | 07:46 PM
CW96's Avatar
Default Re: Where To Get THis Kind Of Heat Wrap? W/PIC!!! (beepy)
That's Brandon's car on TeamRice.org...
http://www.teamrice.org/tr4.0/brandonf.html
Old Jul 3, 2004 | 07:47 PM
IN VTEC's Avatar
It could also be either a vacuum (electric or mechanical) pump, or a dry sump oiling system utilizing a couple of scavenge points on the valve cover.
Old Jul 3, 2004 | 07:51 PM
buck02's Avatar
im a dealer for it i can do a group buy on it if we have a few that want it and diffrent sizes avalible pm me i get u prices
Old Jul 3, 2004 | 10:23 PM
dfoxengr's Avatar
Default Re: Where To Get THis Kind Of Heat Wrap? W/PIC!!! (buck02)
^ advertising is not allowed...
Old Jul 3, 2004 | 10:31 PM
buck02's Avatar
Default Re: Where To Get THis Kind Of Heat Wrap? W/PIC!!! (hybridvteceg)
sorry just tring to help out my fellow h-t members sorry
Old Jul 3, 2004 | 11:56 PM
marshdoggg's Avatar
That stuff is also used on aircraft. you could prolly pay way too much for it at an aircraft maintinence store, usually located on local private/semi private airfields...
Old Jul 4, 2004 | 12:05 AM
Alchemist's Avatar
That stuff is made by Earls. Its really expensive though. For a foot of -10an its like $12.
Old Jul 4, 2004 | 02:51 AM
hax's Avatar
hax
Damn thats a clean engine bay and those heat wrap makes it extra clean! Much better then the classic heat wrap
Old Jul 4, 2004 | 04:00 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buck02 &raquo;</TD></TR><TR><TD CLASS="quote">im a dealer for it i can do a group buy on it if we have a few that want it and diffrent sizes avalible pm me i get u prices </TD></TR></TABLE>
let us know how much its going to be interms of pricing.
Thanks!
Old Jul 4, 2004 | 05:39 AM
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by buck02 &raquo;</TD></TR><TR><TD CLASS="quote">sorry just tring to help out my fellow h-t members sorry </TD></TR></TABLE>
thats cool. but you still cant do it. you are not a sponsor and this is the wrong forum anyways
Old Jul 5, 2004 | 08:50 AM
Default Re: (J General)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J General &raquo;</TD></TR><TR><TD CLASS="quote">Damn thats a clean engine bay and those heat wrap makes it extra clean! Much better then the classic heat wrap </TD></TR></TABLE>
Id get this stuff for the job that it does rather than the way it looks. Regular heat wrap wont perform like this kind will since this one is designed to be used over SS hoses. Ive never seen anyone use regular heat wrap over SS -AN hose or any other type of hose for that matter, only usually exhuast piping.
Old Jul 5, 2004 | 09:17 AM
IN VTEC's Avatar
Default Re: (integra-modder)
That stuff is pretty damn expensive, so if I don't need the thermal insulation/fire retardant characteristics, I'll just wrap the braided line in 3M Super 33+ electrical tape to keep it from chafing against nearby items.
You can also use the silvery-type fiberglass sleeves for that purpose too. I think DEI has that stuff. There's another company where I know you can get it from, but I don't remember the name off the top of my head.
AssItch1
Welding / Fabrication
12
Oct 29, 2009 05:01 PM
geekuskahn6
Oct 11, 2007 09:21 PM
mh
15
Dec 8, 2005 08:28 AM
Heath
Feb 23, 2003 07:03 PM
PM-Performance
Jan 3, 2003 09:41 PM
