best motor to turbo
Old Nov 19, 2001 | 04:19 PM
redteg1's Avatar
Default best motor to turbo
wats ur opinions
Old Nov 19, 2001 | 05:59 PM
maxim's Avatar
Default Re: best motor to turbo (redteg1)
B18b = nice torque
Old Nov 19, 2001 | 08:50 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: best motor to turbo (maxim_force)
The h23 non-vtec is the best, everyone should know that.
Old Nov 20, 2001 | 06:42 AM
immortal's Avatar
Banned
Default Re: best motor to turbo (ForcedAccord)
b18b = weak rods
Old Nov 20, 2001 | 07:37 AM
TurboSedan's Avatar
New User
Default Re: best motor to turbo (immortal)
All Honda motor have weak stock rods compared to any higher end performance cars, so lets not go there. Weak compared to what? I have no proof, I'll admit, but a knowledgable source told me the LS rods are good to about 325hp.
Old Nov 20, 2001 | 10:01 AM
ImportechPerformance's Avatar
I dont know alot about turboing but why not the b20 from crv?? That would be my canidate. Has anyone ever done this? Good or bad exp?? More torque than the b18b?? so why not? ITs not even on your pole. or
Old Nov 20, 2001 | 12:15 PM
b18cTurbo's Avatar
Default Re: best motor to turbo (MrPimpon)
a c5 engine is the best!!!!of corse whit low compression piston
Old Nov 20, 2001 | 03:33 PM
Etylorcen's Avatar
Default Re: best motor to turbo (mikvtec)
Yeah a c5 would be the best for turbo but that still is money. For the all out draggers lots of them run on wild cams only on the non-vtec lobe. Toda spec b's in a c5 on the non-vtec lobe w/ 20psi....
Old Nov 20, 2001 | 04:42 PM
MachAF's Avatar
I agree. I was reading some website where a turbo h23 was doing some where around 600 whp.
Old Nov 20, 2001 | 10:18 PM
bigTom's Avatar
Default Re: best motor to turbo (Etylorcen)
-b18c5 is best for turbo???
-run wild cams on only non-vtec lobes???
-toda spec b's in a itr on the NON VTEC LOBE!!!???
sorry to point u out like this... but all of that is incorrect... when a motor is rebuilt... the b18c1 and the c5 are esentially the same... everything is re-worked... as for my preferance and many other top racers... the c1 head is better...
and the cars run wild cams WITH the vtec lobe... the tricky part is which to use
spec b's on a itr without the vtec lobe makes no sence... actually in a built motor spec bs work well but there are still cams out there that will yield u more power... cant give away all the secrets now though
Old Nov 20, 2001 | 10:23 PM
falcongsr's Avatar
What is this crap?
Default Re: best motor to turbo (ek9t)
haha when i read his post, i figured he meant corvette C5 and i tuned the rest out...
Old Nov 21, 2001 | 07:59 AM
bigTom's Avatar
Default Re: best motor to turbo (falconGSR)
thats what i thought 2!
Old Nov 21, 2001 | 09:31 AM
DRAGLS's Avatar
Default Re: best motor to turbo (97CivicFerio)
ls rods are good for 450+/-hp. On the dyno I measured 363hp on stock rods.
Old Nov 21, 2001 | 09:37 AM
92sleepR's Avatar
New User
Hey redteg1,
Didn't i see your signature icon on Dance Safe .com?
Mike
Old Nov 21, 2001 | 11:08 AM
redteg1's Avatar
Default Re: best motor to turbo (92sleepR)
Hey redteg1,
Mike
hhehehe....maybe, i got mines from erowid's mdma vault
Old Nov 21, 2001 | 12:59 PM
maxim's Avatar
I'm sure someone here can confirm this - doesn't Papadakis have a H23a?
Old Nov 21, 2001 | 01:04 PM
sloaccord's Avatar
New User
thats an h22. . . .
Old Nov 21, 2001 | 01:05 PM
jinxproof99's Avatar
New User
same rods as the ls. but still a good street motor to turbo. 9.6:1 compression.
Old Nov 21, 2001 | 01:16 PM
DLB1994's Avatar
Default Re: best motor to turbo (sloaccord)
its h23 with h22 head so its a h23vtec
Old Nov 21, 2001 | 01:22 PM
schwett's Avatar
New User
h23 with h22 head... build that **** and watch out! to hell with all those little whiny B series engines!
Old Nov 21, 2001 | 03:21 PM
SiRkid's Avatar
hahal.i thought he meant c5 vette to!
i like my b16!!
but i wil probably go b18 block
Old Nov 21, 2001 | 03:23 PM
Dee's Avatar
Dee
Default Re: best motor to turbo (schwett)
H series are torque monsters BUT that massive torque causes some mad traction problems. My choice would be the one that fits your intended usage and doesn't cost you an arm and a leg.
Old Nov 22, 2001 | 07:41 AM
Stunna BEN's Avatar
Don't call it a comeback
Seems that everyone likes the GSR motor. Good for me i have one. What are the limits of boost you can run on a fully stock b18c1? I have seen as much as 12 but then again i said safely!
Old Nov 22, 2001 | 10:15 AM
redteg1's Avatar
Default Re: best motor to turbo (Big Carbon)
i wouldn't boost anything over 9lbs on stock internals of a b18c...just my safe lil opinion.
[Modified by redteg1, 7:15 PM 11/22/2001]
Old Nov 22, 2001 | 11:42 AM
DIRep972's Avatar
Smarter than you
Default Re: best motor to turbo (DRAGLS)
Dayumn! thats alot of power what fuel management were u using?
