for all those who have replaced fuel pumps *need help Now*
Old Jul 2, 2004 | 05:20 PM
HatchBox's Avatar
Skoobie no more...
Default for all those who have replaced fuel pumps *need help Now*
The electrical line that run to the fuel pump how in gods name do i get if off of the circular metal peice (that bolts to the top of the fuel tank) its like a clip on both sides...
Errrrrrrrrrrrrrrrrrrrrrrrrr
Old Jul 2, 2004 | 07:28 PM
Redline130's Avatar
Default Re: for all those who have replaced fuel pumps *need help Now* (Hybrid Hatchback)
If I'm thinking about the same connector, you need to unplug it from inside the car. Under the rear seats there should be a circular panel that is held down with 3 Phillips screws. Undo the screws and the connector will be easily accessible. I hope this is the same plug you are talking about.
Old Jul 3, 2004 | 12:25 AM
misfithamster's Avatar
Default Re: for all those who have replaced fuel pumps *need help Now* (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">If I'm thinking about the same connector, you need to unplug it from inside the car. Under the rear seats there should be a circular panel that is held down with 3 Phillips screws. Undo the screws and the connector will be easily accessible. I hope this is the same plug you are talking about.</TD></TR></TABLE>
yeah im thinkin thats what the dude is talkin about.. maybe describe it a little better? i changed my pump by myself with a jack and two stands...man was it a bitch..
Old Jul 3, 2004 | 10:23 AM
HatchBox's Avatar
Skoobie no more...
Default Re: for all those who have replaced fuel pumps *need help Now* (misfithamster)
ok well where the positive line comes from the pump. it is attatched to the metal cover, and the the line is attatched on both sides, i now know it doenst come off, but mine is broke on top, exposing the positive connecter, do you think it will be arlight?
sorry i cant really explain it all to well, but you guys are thinking of the sender unit, im talking about the fuel pump cover.
Type-Spaz
14
May 11, 2014 01:36 PM
519JDMKING
Sep 23, 2011 03:51 PM
JJexpress
Mar 6, 2010 06:36 AM
hybridshooter
Apr 10, 2008 04:00 AM
birds_sol_94
14
Aug 10, 2004 01:15 PM
