6 psi on a sohc, stock pump and injectors ok
you will probably want some type of rising rate FMU. Those usually come with the SOHC turbo kits. I would recommend upgrading the injectors just a bit. I believe the B series ones flow a little more than the D series injectors. I had a little bit of detonation some times with my Greddy kit, that I think could have been alleviated by doing that.
thanks for the replys guys.
i will be running a v-afc hack. i have dsm 440's and a walbro and a fmu. i was just wondering if i needed to use them.
so one the greddy kit you dont need to up grade the fuel pump! i have some teg injectors i might go with those.
boostincoupe
Oct 6, 2003 06:53 AM
