is there a difference between 94-01 LS and GSR suspension?
Old Jul 2, 2004 | 06:37 AM
tmoney777's Avatar
Default is there a difference between 94-01 LS and GSR suspension?
I wrecked my 98 LS. Just wondering if there is a difference in suspension and brakes between the LS and GSR? Thinking about putting all the suspension and brakes on eg si or selling it. Would appreciate some expertise on this one.
Old Jul 2, 2004 | 06:48 AM
timmy8151's Avatar
Default Re: is there a difference between 94-01 LS and GSR suspension? (tmoney777)
They're pretty much the same. Except the GSR had slightly bigger sway bars and came with a strut tower bar. But the shocks and brakes are exactly the same.
Old Jul 2, 2004 | 08:52 AM
IntEGNYC's Avatar
Default Re: is there a difference between 94-01 LS and GSR suspension? (timmy8151)
timmy speaks the truth!
Old Jul 2, 2004 | 09:02 AM
shamoo's Avatar
Will you make something up for me please?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">They're pretty much the same. Except the GSR had slightly bigger sway bars and came with a strut tower bar. But the shocks and brakes are exactly the same.</TD></TR></TABLE>
Actually....
Only difference is the front strut tower bar on the GSR (none on the LS). Rear sway bars are the same. Fronts are actually thicker in the front of an LS depending on the year. 24mm for the fronts. I guess to promote more understeer?
Old Jul 2, 2004 | 09:09 AM
timmy8151's Avatar
Default Re: is there a difference between 94-01 LS and GSR suspension? (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">
Actually....
Only difference is the front strut tower bar on the GSR (none on the LS). Rear sway bars are the same. Fronts are actually thicker in the front of an LS depending on the year. 24mm for the fronts. I guess to promote more understeer? </TD></TR></TABLE>
Taken from: http://www.team-integra.net/se...ID=43
RS/LS/GS Coupe
Front:
22mm (94-99)
24mm (00-01)
Rear:
13mm
RS/LS/GS Sedan
Front:
22mm (94-99)
24mm (00-01)
Rear:
14mm
GSR
Front:
24mm
Rear:
14mm
ITR
Front:
24mm
Rear:
22mm
Old Jul 2, 2004 | 09:10 AM
FunkDaddyFresh's Avatar
Actually....
Carl Malone says "its about da same"
Old Jul 2, 2004 | 10:59 AM
steven975's Avatar
Default Re: is there a difference between 94-01 LS and GSR suspension? (FunkDaddyFresh)
also, from 98 on, the shocks and springs are the same.
Old Jul 2, 2004 | 02:04 PM
shamoo's Avatar
Default Re: is there a difference between 94-01 LS and GSR suspension? (steven975)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steven975 &raquo;</TD></TR><TR><TD CLASS="quote">also, from 98 on, the shocks and springs are the same.</TD></TR></TABLE>
Shocks and springs have always been the same.
Old Jul 2, 2004 | 02:32 PM
Jdm_Ek_Hatch's Avatar
All the same except for the Strut Bar on the GSR's.
Old Jul 2, 2004 | 04:14 PM
tmoney777's Avatar
Default Re: is there a difference between 94-01 LS and GSR suspension? (Jdm_Ek_Hatch)
Thanks
DuVaL rAcEr
Jan 26, 2008 09:28 AM
The_Nomad
May 20, 2005 02:07 PM
ckyguy
Suspension & Brakes
Feb 21, 2005 07:55 AM
stevey
Oct 30, 2003 11:09 AM
RacerXintegra2k
Sep 29, 2002 04:42 PM
