Can 15 inch rims fit my 95 cx hatch back?
Old Jul 1, 2004 | 11:12 AM
uniacke-hatch's Avatar
Default Can 15 inch rims fit my 95 cx hatch back?
Can I put 15 inch steel rims on my little 95 hatchback? I want to run 195/55R15 on it for the summer. This size won't change my outside diameter. But might the tires rub on the wheel well when I turn or hit big bumps?
Old Jul 1, 2004 | 11:15 AM
mafioso102's Avatar
New User
Default Re: Can 15 inch rims fit my 95 cx hatch back? (uniacke-hatch)
yeah...people put 17's on hatches all the time (unfortunately)
Old Jul 1, 2004 | 11:19 AM
Built to Spill's Avatar
el diablo
Is you car lowered at all?
If so then you could have some rubbing (depending on the drop) with 55 series tires. If your car is stock height then you have nothing to worry about.
eastbay92cx's Avatar
It should change the outside diameter a little if you are currently using oe sized tires and wheels (I think 175/70/13). The new tires will be bigger and wider but they should still fit and I doubt you'll have much rubbing especially if you aren't that low. good luck
Old Jul 1, 2004 | 11:29 AM
B18C5-EH2's Avatar
Former Moderator
Loved
You need 195/50/15 tires or at most 205/50/15 tires. 195/55/15 will look like **** because the sidewall is so damn tall.
I run 15'' wheels on both of my 92 hatches.
205/50/15:
195/50/15:
They fit
Old Jul 1, 2004 | 11:43 AM
Default Re: Can 15 inch rims fit my 95 cx hatch back? (B18C5-EH2)
Actually I just checked and 195/50R15 is better cause of the outside diameter difference. So I'll probably go with those. The car is not lowered at all. Good to know they'll fit fine.
Old Jul 1, 2004 | 11:47 AM
JimmyAtlantis's Avatar
Jesus, Tom! I though that was my car until I saw the others.
edit: Yes they will fit and this ^ is a good, lightweight wheel. Weight is of importance.
Old Jul 1, 2004 | 12:29 PM
crzymine03's Avatar
i've seen hatchbacks wiht 19'' so u can put 15'' for sure
Old Jul 1, 2004 | 12:39 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uniacke-hatch &raquo;</TD></TR><TR><TD CLASS="quote"> I want to run 195/55R15 on it for the summer. This size won't change my outside diameter. </TD></TR></TABLE>
yes it will,
thats alot taller than the stock diameter
Old Jul 1, 2004 | 12:49 PM
Default Re: Can 15 inch rims fit my 95 cx hatch back? (Tad)
which is why I said I'd use 195/50R15 instead like was suggested by B18C5-EH2.
Old Jul 1, 2004 | 12:51 PM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uniacke-hatch &raquo;</TD></TR><TR><TD CLASS="quote">which is why I said I'd use 195/50R15 instead like was suggested by B18C5-EH2.
Yes yes grasshopper. Learning fast, you are.
Old Jul 1, 2004 | 01:02 PM
Tad's Avatar
Tad
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uniacke-hatch &raquo;</TD></TR><TR><TD CLASS="quote">which is why I said I'd use 195/50R15 instead like was suggested by B18C5-EH2.</TD></TR></TABLE>
swell
Old Jul 1, 2004 | 01:08 PM
chronodyne28's Avatar
Default Re: Can 15 inch rims fit my 95 cx hatch back? (mafioso102)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mafioso102 &raquo;</TD></TR><TR><TD CLASS="quote">yeah...people put 17's on hatches all the time (unfortunately)</TD></TR></TABLE>
When you really think about it the total diameter of a 15 inch rim and the tire on it it will come out just over 17 inches. So having 17's with a rubberband tire doesn't exactly put the car in the air like most say. It does cut down on ride comfort a whole lot though. But having 17's on hatches...for some reason it just doesnt look good. Looks better on coupes I guess. I'd say since you have a hatch stick with the 15's and I don't think they'll rub at all unless your car is slammed.
Old Jul 1, 2004 | 01:16 PM
dantastic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">You need 195/50/15 tires or at most 205/50/15 tires. 195/55/15 will look like **** because the sidewall is so damn tall.
wow... if you can tell the difference between 195/55 and 205/50 by looking, you're quite a tire expert... 107.25mm vs 102.5mm sidewall heights. btw, 195/55 is the factory size tire on 94+ integra gsr and 99-00 civic Si
Old Jul 1, 2004 | 01:20 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Can 15 inch rims fit my 95 cx hatch back? (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">
wow... if you can tell the difference between 195/55 and 205/50 by looking, you're quite a tire expert... 107.25mm vs 102.5mm sidewall heights. btw, 195/55 is the factory size tire on 94+ integra gsr and 99-00 civic Si</TD></TR></TABLE>
Seeing as how I sell tires at the shop I work at (have for 3 years) I'd consider myself well versed in the area.
You can definately tell the difference in a 195/55/15 compared to a 205/50/15 because the 55 series looks taller. The 205 will hang over the wheel a bit more. Trust me 55 series looks retarded on 92-95 Civics. I had some OE 99 Civic Si wheels and tires (195/55/15 Mich XGTV4) on my fiancee's 92 Si HB back in 2000 and believe me, they looked damn silly compared to 205/50/15s.
Old Jul 1, 2004 | 01:32 PM
dantastic's Avatar
[benstiller dodgeball voice] touche![\]
in anycase, 205/50 &gt; 195/55 &gt; 195/50 imo. 195/50 looks too skinny and tiny
Old Jan 7, 2015 | 12:44 PM
biggnate81's Avatar
I have a 95 ex coupe I was wondering if I could run 15x6.5 wheels with a 38 offset with 195/50/15 with 1.75" lowering springs
Old Jan 7, 2015 | 12:55 PM
NotARaCist's Avatar
I never narc'd on nobody!
First off, this thread you just necro'd is over a decade old. Don't do that. Ever. Period. Second off, check where you're posting before you post - the first thing you see might not be the right answer. In your case, the right thread would have been the wheels and tires section. Third off, yes.
Old Jan 7, 2015 | 02:17 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
^ Well put. Ancient thread closed.
Change Me
Honda Civic (2001 - 2005)
Apr 14, 2007 07:16 PM
Kapetan
14
Jan 11, 2006 07:36 AM
M-Type
Apr 1, 2003 10:32 AM
dynamo
Oct 19, 2002 03:23 PM
4doorRS5spd
Feb 5, 2002 06:19 PM
