civic si header work with a gsr?
Old Jul 1, 2004 | 08:15 AM
HulkSmash's Avatar
Default civic si header work with a gsr?
my friend has a dc 4-1 header that came off his 99 civic si. will this header fit in my gsr? thanks
Old Jul 1, 2004 | 11:26 AM
You_Get_Vapors
Guest
Posts: n/a
Default Re: civic si header work with a gsr? (HulkSmash)
It will be too short. Won't clear the oil pan. Sorry
Old Jul 1, 2004 | 01:17 PM
SuzukaBlueAP2's Avatar
Default Re: civic si header work with a gsr? (You_Get_Vapors)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by You_Get_Vapors &raquo;</TD></TR><TR><TD CLASS="quote">It will be too short. Won't clear the oil pan. Sorry</TD></TR></TABLE>
huh? How's that?
Old Jul 1, 2004 | 01:24 PM
G-bonic's Avatar
Hijacked
Yes it would work maybe youll need some modifications...
Old Jul 1, 2004 | 01:46 PM
greaseball's Avatar
right. it will be too short to clear the oil pan. it will bolt up fine, but not clear the oil pan.
Old Sep 7, 2004 | 08:17 PM
blue_dlb's Avatar
Default Re: civic si header work with a gsr? (greaseball)
can someone else confirm that it will not clear the oil pan.
Old Sep 7, 2004 | 08:50 PM
BlueIntegraBoy's Avatar
Default Re: civic si header work with a gsr? (blue_dlb)
Si = 1.6L
GSR = 1.8L
Taller block perhaps? Hmm...
Old Sep 7, 2004 | 08:56 PM
Sack Master's Avatar
Default Re: civic si header work with a gsr? (BlueIntegraBoy)
I'll confirm it. Headers are designed to hug the pan to give as much ground clearance as possible. A b16 block is a little shorter therefore the header is a little shorter. It would work the other way but there will be a big gap between the pan and the header.
Old Sep 7, 2004 | 09:03 PM
lga860's Avatar
Default Re: civic si header work with a gsr? (Sack Master)
Ill confirm also... cuz i still have a b16 dc 4-1 header that i tried to put on a friends gsr and it doesnt clear the oil pan and the mounts for the header dont line up. sorry...
Old Sep 9, 2004 | 10:01 AM
blue_dlb's Avatar
okay i also confirmed it myself. The head bolts pattern are not the same. The lower corner head bolts are different but the others look fine. Definitely won't work.
Old Sep 9, 2004 | 11:01 AM
Default Re: (blue_dlb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue_dlb &raquo;</TD></TR><TR><TD CLASS="quote">okay i also confirmed it myself. The head bolts pattern are not the same. The lower corner head bolts are different but the others look fine. Definitely won't work.</TD></TR></TABLE>
They are the same
Old Sep 9, 2004 | 11:15 AM
CNSK's Avatar
Default Re: (Sack Master)
it will fit...just the length of the piping will be different.....integra headers are shorter and b16/type R header is longer
Old Sep 9, 2004 | 12:13 PM
Dc4turbo408's Avatar
Default Re: (Moua)
OH for sure!!
slow91crx
Welding / Fabrication
Jun 7, 2006 06:07 AM
92gsr1
Aug 15, 2005 05:01 PM
Shakes
Mar 28, 2004 07:25 AM
MidoriEK4
May 26, 2003 05:02 PM
