Instead of a C5 bottom end, What if. . .
What if I just used an ITR crank and went w/aftermarket rods/pistons on my b16
wouldnt that be cheaper? I'm sure this has to be effective in some way or another instead of buyin the entire bottom end. .
The way I look at it is the b16 has a shorter deck height than the b18 and if i have a type r crank, then i have the type r's rod/stroke ratio, but in a b16. . . wouldnt i have more compression because of the shorter deck heigh??
Cuz i was lookin at the toda stroker kit, only thing that really makes anything different in that kit is the crank right? (besides the different c/r pistons)
somenoe enlighten my path to NA-ism
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 »</TD></TR><TR><TD CLASS="quote">but in a b16. . . wouldnt i have more compression because of the shorter deck heigh?? </TD></TR></TABLE>
Ummm...you won't have more compression because you won't be able to bolt the head down with the pistons sticking out so high. If you want to attempt this, then contact Tech43 Racing and ask about their kits to allow this kind of thing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 »</TD></TR><TR><TD CLASS="quote">so your sayin its a waste of time then . ?
</TD></TR></TABLE> YES... like Kendall said, get the Tech43racing kit
Good luck on your build mr. 209
bweezy615
Jun 18, 2008 04:08 PM
Topdawgg
Apr 21, 2007 07:25 PM
Cidone
Oct 1, 2004 04:43 AM
