head gasket seal problem? rings? valves sealing? help!
Old Jun 30, 2004 | 10:34 PM
darrinbrewer's Avatar
Default head gasket seal problem? rings? valves sealing? help!
went to the race track to race car. after slowing down the car spit & sputtered and died. had to hold the throttle way open to get restarted, but got back to the pits, let it set for a while, then it started up fine and drove home, just had a slight miss at idle.
i decided to hit vtec on the way home to see if i could make it go wild again, as a neared 7000 rpm, it just went spittin and sputtering again, i COULD NOT let off the gas or it would die.
so i thought that it would be that i may have bent some valves. i took the head off and took it to the machine shop he put new valves, valve springs, seals, the whole 9 yards.
i put the head back on and used some arp studs,now it smokes like crazy.out the exhaust and white smoke from the valve cover breather, not sweet smelling like anitfreeze, but strong gas odor, it would build up pressure if i kept my finger on the hole,
the motor has 176,00 miles on it and nothing has been done other than type r cams / valve springs
compression was at 180 in 1,2,3 but 165 in #4
AFTER the headwork,like 120,140,130, and #4 had 190!
any ideas? $70+ head gaskets suck to buy when you go through a couple
Old Jun 30, 2004 | 10:44 PM
Bspec18's Avatar
Default Re: head gasket seal problem? rings? valves sealing? help! (darrinbrewer)
when you took the head off how did the old headgasket look ? or the block ?
Old Jun 30, 2004 | 10:49 PM
Default Re: head gasket seal problem? rings? valves sealing? help! (Bspec18)
well 2 local honda guys (speedworks and saleensolution-its at his house) looked at it and said the block looks fine, and couldn't really tell anything from the head gasket either
Old Jun 30, 2004 | 10:59 PM
Bspec18's Avatar
well, given the fact you had no head work done, and you put a new head gasket in (you did put alot of copper spray when you installed it ?) Only thing i could think next is the head or block is warped or your rings are done
Old Jun 30, 2004 | 11:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bspec18 &raquo;</TD></TR><TR><TD CLASS="quote">well, given the fact you had no head work done, </TD></TR></TABLE>
i did have head work done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darrinbrewer &raquo;</TD></TR><TR><TD CLASS="quote"> i took the head off and took it to the machine shop he put new valves, valve springs, seals, the whole 9 yards. </TD></TR></TABLE>
they made sure twice that the head was straight and true...didn't use any copper spray, i havent' seen anyone use that locally, around here anyway, it may be a common thing elsewhere...and no one else has problems
Old Jul 1, 2004 | 02:09 AM
Quitripin's Avatar
do a compression test and leak down test
Old Jul 1, 2004 | 02:02 PM
Default Re: head gasket seal problem? rings? valves sealing? help! (Quitripin)
looking for some input from you guys
Old Jul 1, 2004 | 02:17 PM
Bspec18's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quitripin &raquo;</TD></TR><TR><TD CLASS="quote">do a compression test and leak down test</TD></TR></TABLE>
well seeing as his numbers are already low, i don't see how another test will help.
did your machinist do a 3 angle valve job or any porting ? Did you check the block for warpage ? i've seen many builders here in my area put alot of copper spray for better sealing
Old Jul 2, 2004 | 04:32 PM
ended up being rings looks like (read saleensolutions post below), so i'm getting soft radius'd arias 20 over flat top pistons from Alaniz, eagle rods(more than likely) and ACL bearings now..total since car started acting funny: $2600! but that includes above, $400 for skunk2 cams, ferrea valves, poerflow inner valvesprings too, a few head gaskets, other gaskets and seals...etc..
Modified by darrinbrewer at 11:52 PM 7/3/2004
Modified by darrinbrewer at 11:53 PM 7/3/2004
Old Jul 3, 2004 | 10:25 AM
saleensolution's Avatar
all the blow by was comin up through the oil drain vent holes on one and three. but on two and three at 45 psi it had 10 percent leakage which is good
mediajunkie420
Oct 7, 2013 12:34 PM
markers.
Feb 6, 2010 04:54 PM
jyacoba2009
Nov 23, 2009 08:25 PM
dansf100
Oct 26, 2009 05:22 PM
chero112
Oct 11, 2004 09:43 AM
