CRX won't start, please help.
Old Jun 30, 2004 | 10:03 PM
crex23's Avatar
Default CRX won't start, please help.
I have a 89 DX that wouldn't start today. I jumped it off and it ran fine until I shut it off. I replaced the plugs recently, and I hear the fuel pump when I turn the key. All my fuses are good. But all it does is crank, it won't turn over.
I posted not too long ago about my car hesisating and stuttering when I accelerate. Also, the dash and console lights dim at night when I stop. It's like something is draining the power.
I replaced the battery and alternator about 3 years ago, and recently had the battery tested again because of the problems mentioned above, and it tested ok.
Do I need a distributor? I also replaced the ignitor because of the 'bouncing' tach problem, but that didn't help much.
Any advice would be appreciated. Thanks.
Old Jul 1, 2004 | 08:09 AM
crex23's Avatar
Default Re: CRX won't start, please help. (crex23)
Old Jul 1, 2004 | 09:17 AM
crex23's Avatar
Anyone?
Old Jul 1, 2004 | 09:22 AM
REDBARON's Avatar
The bouncing tach sounds like a distributor problem. If possible, test it with a known good one.
The dimming lights sounds like a alternator issues. Double check the alternator connections. If everythings is connected good, then get it checked out.
Also I would check all the grounds.
ScalCG6
Mar 28, 2019 04:56 PM
eltoro16
Dec 6, 2013 05:44 PM
mistablaz3
May 9, 2011 01:01 PM
djsire
Nov 9, 2005 02:21 PM
AzntstyleZ
10
Feb 27, 2004 10:50 PM
