gauges jumping all crazy?
Old Jun 30, 2004 | 09:35 PM
eg ferio's Avatar
Default gauges jumping all crazy?
ok i have a stock b16a2 in my eg...ive been having this problem that everytime i take my car pass like 65krpm my rpm gauge starts jumping all crazy and jumps real fast past red line......also i noticed that everytime i step on the gas my temperature gauge jumps to cold then goes back to normal i step on it again and jumps down to cold then gets back to normal....and everytime i put my blinkers on my speedometer and my rpm gauge jump erratically and my clock begins to flash along with the blinkers....?????????? im thinking the blinker problem seems to be a short circuit but im still unsure of everything else....your help is greatly appreciated
Old Jul 1, 2004 | 12:29 AM
Circuit Star-29's Avatar
Default Re: gauges jumping all crazy? (eg ferio)
YOur wiring is Fugged. Tracing time. I had to do it one time took me four days. or you can take to the stealer. Good luck. ITs often just a mis connection
Old Jul 1, 2004 | 05:20 AM
eg ferio's Avatar
Default Re: gauges jumping all crazy? (nathan atwell)
any other ideas?
Old Jul 1, 2004 | 05:13 PM
eg ferio's Avatar
Old Jul 1, 2004 | 05:23 PM
doublejz's Avatar
check your grounds, happened to me before
Old Jul 1, 2004 | 05:43 PM
eg ferio's Avatar
Default Re: gauges jumping all crazy? (doublejz)
ill check the grounds...anything else i should look for?
Old Jul 2, 2004 | 05:02 AM
eg ferio's Avatar
grounds are ok...anything else?
Old Jul 2, 2004 | 08:52 AM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">check your grounds, happened to me before</TD></TR></TABLE>
Double check. Make sure that there is not a rubber grommet or gasket material under any of them and that there are good connections at both ends I stumped for almost a week because of a rubber grommet
Old Jul 2, 2004 | 10:23 PM
eg ferio's Avatar
Default Re: gauges jumping all crazy? (hondaguyef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaguyef &raquo;</TD></TR><TR><TD CLASS="quote">
Double check. Make sure that there is not a rubber grommet or gasket material under any of them and that there are good connections at both ends I stumped for almost a week because of a rubber grommet </TD></TR></TABLE>
yea ima double check again just to make sure..thanx
Old Jul 2, 2004 | 10:42 PM
drunknbass's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">check your grounds, happened to me before</TD></TR></TABLE>same here.. check them all.. the main one to check is the battery ground.. but theres also a ground behind your dash thats part of the harness
OhMyTofu
Audio / Security / Video
Oct 17, 2009 08:12 PM
Methane2k2
Aug 3, 2005 10:39 PM
Jonathan_ED3
Apr 3, 2005 11:47 PM
Djrockz415
Aug 29, 2003 02:47 PM
89 CRX SI
Aug 21, 2002 09:00 AM
