valve grind???
Old Jun 30, 2004 | 07:48 PM
ludetech
Guest
Posts: n/a
Default valve grind???
ok I have an extra h22 head I took it in to get it checked out and the guy said it need a valve grind. what exactly is this? why would I need something like this. the motor that the head was off of, the guy drove into a puddle or something and his cai sucked up some water, bent 2 rods and that was it I thought. anyways can someone explain this?
Old Jun 30, 2004 | 09:20 PM
JDMotive's Avatar
Default Re: valve grind??? (ludetech)
I dont know why it would need a valve grind,maybe he was talking about having the valve seats recut,if they were rusty.
Old Jul 1, 2004 | 06:23 AM
Sliced Beard's Avatar
Default Re: valve grind??? (JDMotive)
honda heads have steel inserts where the valve seals the head and if they were to rust you will loose sealing effectiveness. you most likely need a valve cut/grind and lapping
this is where the valve's seal is restored, ask what style of cut that they are going to do. request either a radius cut or a multi angle for better flow
KoRE
Apr 13, 2010 09:40 PM
VSBB6
Sep 11, 2005 11:07 AM
D50boy
14
Jun 6, 2005 08:52 AM
BigC-ivic
Oct 22, 2004 02:46 PM
skribblah
Jun 30, 2003 08:10 PM
