Crankshaft Pulley Key.
Old Jun 30, 2004 | 03:47 PM
steve_s's Avatar
Default Crankshaft Pulley Key.
I just got my jdm d15b and I started changing the timing belt on it. When I get to take the crankshaft pulley off it comes off with ease (impact wrench ). But then I notice there is no key there? How easy are they to get from honda? Also..., since there is no key, is the engine okay?, how do i know or not.
Old Jun 30, 2004 | 05:22 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Crankshaft Pulley Key. (steve_s)
chances are you dropped it when the pulley came off. should be able to get it from the dealer. let me see if i can get you a part number.
Old Jun 30, 2004 | 05:28 PM
Mr. Badwrench
Default Re: Crankshaft Pulley Key. (boostedcivicsir)
90704-634-000
that should be the part number you need.
thats for the d16z6 but should be the same. make sure you check it with your dealer. i take no responsibility for wrong part numbers. he hee. this is just what i find on a site i have saved in my favorites.
Old Jun 30, 2004 | 05:43 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
I'm pretty sure all the crank pulley keys should be ok. Your motor will be OK if there wasn't a key there since the crank pulley only powers the engine accessories.
Old Jun 30, 2004 | 06:59 PM
dantastic's Avatar
Default Re: Crankshaft Pulley Key. (HondaFanatic708)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaFanatic708 &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure all the crank pulley keys should be ok. Your motor will be OK if there wasn't a key there since the crank pulley only powers the engine accessories.</TD></TR></TABLE>
yea, but it'll make it difficult to set the ignition timing correctly
Old Jun 30, 2004 | 07:02 PM
clm's Avatar
clm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">90704-634-000 </TD></TR></TABLE>
I believe that is the number for the crank pulley key. Used on multiple models IIRC and your locak Honda dealership should have it in stock.
Old Jun 30, 2004 | 08:47 PM
steve_s's Avatar
Default Re: Crankshaft Pulley Key. (clm)
Thanks for the help guys, i was really worried there for a second.
tolowhb
Sep 20, 2009 10:18 AM
bow tie
Oct 17, 2008 01:18 PM
street_ride14
May 13, 2007 04:35 PM
white_panther
Dec 8, 2006 04:47 PM
HXvtec
10
Jan 1, 2004 07:26 PM
