How to adjust and determine fuel pressure with an aem fpr
Old Jun 30, 2004 | 02:39 PM
fishnfst's Avatar
Default How to adjust and determine fuel pressure with an aem fpr
Hello I want to install a aem adjustable fpr into my ek. I would like to run around 50lbs of fuel pressure. How do you know where to adjust the fpr to. It does not have a gauge or a port for a gauge. I know their fuel rail has a port for a gauge but I don't need a 100 dollar fuel rail. I thought about purchasing a b and m gauge setup that replaces the banjo fitting on your fuel filter but is there a better way?
Old Jun 30, 2004 | 03:34 PM
Padawan's Avatar
Darth ModerVader
Default Re: How to adjust and determine fuel pressure with an aem fpr (fishnfst)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fishnfst &raquo;</TD></TR><TR><TD CLASS="quote"> I thought about purchasing a b and m gauge setup that replaces the banjo fitting on your fuel filter but is there a better way?</TD></TR></TABLE>
What's wrong with this solution? The B&M gauge is inexpensive, easy to install, and it works, so it seems like an excellent option to me.
Old Jun 30, 2004 | 06:37 PM
fishnfst's Avatar
I was just wondering if there was another way. I guess aem wants you to buy their fuel rail to use with the fpr wether you need it or not.
Old Jun 30, 2004 | 06:39 PM
dantastic's Avatar
i have a b&M gauge... works well for all i know... but the b7m fpr is crap. i couldnt get it to set my pressure correctly at all
Old Jun 30, 2004 | 06:55 PM
91civicDXdude's Avatar
I had a complete B&M FPR and gauge set for a while. I never have had a problem with the B&M and it is still on my car, although having the fuel pressure gauge on my car for about 6-8 months, it started reading higher and higher and i thought it was my regulator. I swapped it with a stock regulator and it still read like 80psi. The gauge was broken. I got a liquid filled gauge from Summit and havent had a problem since.
this is just my experience. I hav ea friend with the B&M set and has never had a problem.
Old Jun 30, 2004 | 06:58 PM
Padawan's Avatar
Darth ModerVader
Default Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">but the b7m fpr is crap. i couldnt get it to set my pressure correctly at all</TD></TR></TABLE>
The B&M FPR we installed in my brother's car works extremely well. Our tuner had no problems adjusting it when we took the car for tuning, and it's continued to function nicely ever since.
ochsy03
Jul 10, 2005 08:17 AM
isumase
Apr 29, 2005 11:27 AM
FourthGenHatch
10
Feb 29, 2004 07:35 AM
b18cya
Apr 10, 2003 09:24 AM
