250 wheel hp
Old Jun 30, 2004 | 12:34 PM
sauter's Avatar
Default 250 wheel hp
I have a 95 acura integra special edition. Im tryin to figure out what would be the best way to create 250 wheel hp without doing internals and spending tons of money. Although cams would not be a big thing. Maybe types of turbos suggested etc. Can ya help me?
Old Jun 30, 2004 | 12:35 PM
Chris's Avatar
Default Re: 250 wheel hp (sauter)
please read more.. there are a million posts with a million ways.
Old Jun 30, 2004 | 12:46 PM
Dawsonb17a's Avatar
New User
Yeah man, just do some searches, scan some pages.
In order to get 250whp you are going to have to turbocharge your car. And if you want it reliable you will most likely have to build up the internals.
Old Jun 30, 2004 | 12:48 PM
3.504's Avatar
Default Re: 250 wheel hp (Chris)
quick answer: turbo kit, like drag111 or revhard. whatever you prefer. many people with LS motors have tuned over 300 horse on stock LS motors w/ nothing more than a turbo setup and a little fuel management. look to spend around 3000 for the turbo kit, and about 1000 for some type of management.
Old Jun 30, 2004 | 01:20 PM
_noname_'s Avatar
search is your friend!
Old Jun 30, 2004 | 01:23 PM
Hussein Fatal's Avatar
Default Re: 250 wheel hp (skx)
use the search feature and type in stuff like turbo, or the name of ure engine, and loads of **** is gona pop up, see what you want and make an "educated" decision...good luck with ure ****
Peace
Old Jun 30, 2004 | 03:05 PM
94gsr4dr's Avatar
Default Re: 250 wheel hp (InsaneTeg)
Turbo, but you need to do some homework before you do anything. If you do it now i give it 42 minutes before you blow it up.
Old Jun 30, 2004 | 03:11 PM
VTECorona's Avatar
Default Re: 250 wheel hp (94gsr4dr)
Turbo is the easiest and cheapest. It won't be "cheap," plan to spend 4-5 large.
Old Jun 30, 2004 | 07:13 PM
shermanyang's Avatar
Default Re: 250 wheel hp (VTECorona)
I BID YOU TO THE DARK SIDE.... it's the only way...the easiest way...
Old Jun 30, 2004 | 07:14 PM
FlaN.'s Avatar
turboperiod
Old Jun 30, 2004 | 07:18 PM
GS-Rdriven's Avatar
I would suggest rev hard and maybe some hondata and you definitley need some extra money for tuning..more hp=more $$, beware of that.
Also do a lot of research before buying anything.
Knowledge is (horse) power.
Old Jun 30, 2004 | 09:23 PM
WhiteGSR95's Avatar
250hp all mototr will be tough. turboed not so tough. lol just about ure preference
Old Jun 30, 2004 | 10:12 PM
Kendall's Avatar
Hmmm...stock internals...you have a few options:
1. Fill your gas tank with nitromethane. You'll make far more than 250 at the wheels, but don't expect the engine to last more than about a minute and a half before it blows up.
2. Use lots of nitrous oxide. It will take close to a 300 shot to put you at 250 horsepower so don't plan on the engine lasting longer than about a minute and a half before it blows up.
3. Buy a turbo kit and have it properly tuned.
Old Jun 30, 2004 | 10:54 PM
HKG-DC2's Avatar
u have to spend a tons of money to make ur NA setup over 200whp..
so turbo would be way easier...
depends on which one u like better - NA or Turbo..
Old Jul 1, 2004 | 02:03 AM
oldskool teggy's Avatar
Default Re: 250 wheel hp (HKG-DC2)
wats ur budget like? i'd say a 100 shot direct port nos, with IHE, and 403 crower cams. if you want something to drive well, swap out your motor for a b20z. 2.0L 100 direct port, and IHE with 403 cams.. good ish!
Old Jul 1, 2004 | 02:04 AM
Kendall's Avatar
Default Re: 250 wheel hp (Oldskool teggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Oldskool teggy &raquo;</TD></TR><TR><TD CLASS="quote">wats ur budget like? i'd say a 100 shot direct port nos, with IHE, and 403 crower cams. if you want something to drive well, swap out your motor for a b20z. 2.0L 100 direct port, and IHE with 403 cams.. good ish!</TD></TR></TABLE>
However, with stock compression the 403's are really pointless, plus you would need to upgrade the valvetrain as well.
Old Jul 1, 2004 | 02:23 AM
SSR'd's Avatar
Default Re: 250 wheel hp (3.504)
usually a drag/revhard kit with basic tuning yield approximately 220-230whp @ 7psi
MugenGSR2001
Feb 8, 2005 04:47 PM
IntegraPrez
Oct 10, 2004 06:59 PM
Teinman
Jul 7, 2004 05:58 PM
dohc-nyne
Apr 19, 2003 08:10 PM
BranzLS
Apr 22, 2002 06:45 PM
