rod cap stuck on there... any advice?
hey... im disassembling my motor and one of the rod caps just doesnt want to come off of the crank.
i have a bad feeling something horrible will be discovered, theres a LOT of play on that rod cap. any advice?
Will it not come off the rod or will not come off the crank. If you cant get it off of the rod back out the rod bolts or nuts if you have stock rods. About a 1/4 inch or so. Than with a plastic hammer you can tap the tops of the bolts to get them to seperate.
stumpyf4
Aug 4, 2007 06:33 AM
