odd ecu question....
Old Jun 30, 2004 | 09:47 AM
Phatch99's Avatar
Default odd ecu question....
If i have obdII car with b16 ecu that throws a code for secondary 02 sensor, would this work if i buy harness conversion obdII to obdI and plug in a p72 ecu? all are the ecu pin of a obdI gsr ecu the same as the 99 b16 ecu if you have the conversion harness??? help?????
Old Jun 30, 2004 | 10:48 AM
Joseph Davis's Avatar
Default Re: odd ecu question.... (Phatch99)
For a conversion to OBD1, you'd want an ECU that was for, or chipped for, a B16. Using a GSR P72 isn't it.
Secondary O2 sensor problem pop up after an exhaust, removal of a cat, or something like that? If so, you can just remove the secondary O2 sensor from the exhaust stream, but leave it plugged in and zip tied out of the way, and you get no CELs. The ECU is just using it as a pass/fail test to ensure mixture past the cat is leaner... an O2 sensor in open air reads lean.
Old Jun 30, 2004 | 11:31 AM
Phatch99's Avatar
Default Re: odd ecu question.... (J. Davis)
wouldn't a gsr p72 by right for my set-up? lsvtec with gsr head obdI both parts going in a ODBII car? b16 seems to work fine but gsr doesn't..... dont' know why?
Old Jun 30, 2004 | 01:02 PM
You never said LS/VTEC previously, I just saw B16 and ASSumed.
A B16 ECU will run a GSR or LS/VTEC lean, just like a GSR ECU will run a B16 too rich.
matto2413
May 10, 2005 01:27 PM
Phatch99
Jul 6, 2004 11:22 AM
Phatch99
Jun 30, 2004 11:25 AM
drunken jdm monkey
Jul 23, 2002 05:57 PM
