Odd ecu question......
Old Jun 30, 2004 | 09:44 AM
Phatch99's Avatar
Default Odd ecu question......
If i have obdII car with b16 ecu that throws a code for secondary 02 sensor, would this work if i buy harness conversion obdII to obdI and plug in a p72 ecu? all are the ecu pin of a obdI gsr ecu the same as the 99 b16 ecu if you have the conversion harness??? help?????
Old Jun 30, 2004 | 10:32 AM
egsleepercivic's Avatar
or you could get an 02 simulator, might be a little cheaper
Old Jun 30, 2004 | 11:23 AM
Cnote's Avatar
Default Re: Odd ecu question...... (Phatch99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatch99 &raquo;</TD></TR><TR><TD CLASS="quote">If i have obdII car with b16 ecu that throws a code for secondary 02 sensor, would this work if i buy harness conversion obdII to obdI and plug in a p72 ecu? all are the ecu pin of a obdI gsr ecu the same as the 99 b16 ecu if you have the conversion harness??? help?????</TD></TR></TABLE>
you can splice your secondary wires to your primary and won't throw code....not recommended but will work
Old Jun 30, 2004 | 11:25 AM
Phatch99's Avatar
Default Re: Odd ecu question...... (Cnote)
i have 99 b16 engine harness (lsvtec) 99h/b everybody says that the gsr ecu will perform better than the b16 ecu, is that correct? if so then i would like to run the gsr ecu.... i have conversion harness already but with gsr ecu vtec doesn't engages but no power.....
B16Ben
12
Sep 29, 2011 10:28 AM
creepy116
Dec 8, 2007 01:25 PM
stw88crx
Jul 1, 2007 06:39 PM
Phatch99
Jun 30, 2004 01:02 PM
Renegade
Aug 29, 2003 09:17 AM
