B18C1 CRX ECU Questions
Old Jun 30, 2004 | 08:28 AM
spcrxracer's Avatar
Default B18C1 CRX ECU Questions
I have a 91 CRX DX with an OBD-I GSR motor in it. Currently, a ZDyne gold series ecu is running my car. The ecu is for a b16a though. My question is do you think i should try to find the p72 GSR ecu or just stick with the zdyne one??
Old Jun 30, 2004 | 08:54 AM
crx_88_si's Avatar
if you can change fuel/timing with yours. I would just run 95 gsr maps on the ecu.
Old Jun 30, 2004 | 09:01 AM
4drEF's Avatar
Keyboard Humorist
Default Re: B18C1 CRX ECU Questions (spcrxracer)
go get the zydene tuned.
Old Jun 30, 2004 | 10:07 AM
EF_LSVtec's Avatar
Default Re: B18C1 CRX ECU Questions (4drEF)
It depends if you're running your car stock or with mods...ideally, you want the P72 if you're running a stock motor because of the dual runners...but as everyone said, it's best to just get your Zdyne tuned to how your car is currently set up. Is you car wired for obd1? Because you may need a conversion harness if you want to run the P72 and still wired obd0.
Old Jun 30, 2004 | 12:17 PM
Rywire's Avatar
Default Re: B18C1 CRX ECU Questions (EF_LSVtec)
The p28 (chipped) is a great choice if you are using a custom IM, and the p72 is good for the stock IM. Assuming you are obd1.
Old Jun 30, 2004 | 12:19 PM
4drEF's Avatar
Keyboard Humorist
Default Re: B18C1 CRX ECU Questions (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">The p28 (chipped) is a great choice if you are using a custom IM, and the p72 is good for the stock IM. Assuming you are obd1.
I don't think that setup can come close to even touching a tuned Zydene.
Old Jun 30, 2004 | 03:12 PM
Rywire's Avatar
Cool, ya, Ive never used zdyne.
Old Jun 30, 2004 | 09:44 PM
spcrxracer's Avatar
Well right now my car is the stock gsr motor, with intake, headers, cat, exhaust. Im thinking of getting the p72 ecu untill i do full fuel systems/mild internal work next year. id still keep the zdyne one (obviously) and run it when my car is ready to be tuned
Civic483973
Jul 30, 2010 09:26 AM
DOHC Kid
May 27, 2008 05:41 PM
b00sted4dr
Feb 7, 2008 09:17 AM
Mikes2000civicsi
Jan 30, 2007 11:42 AM
Tsunami_racer
Aug 20, 2006 11:13 PM
