Wiring gauges to dimmer switch
Old Jun 30, 2004 | 07:47 AM
jisu009's Avatar
Default Wiring gauges to dimmer switch
Does anyone know the specfic wire that I would use for power to my autometer gauges, in order to have them dim with the dimmer switch?
I have measured the voltage for each of the three wires on the back of the dimmer switch and they only measure between 2.75-5.85 Volts. I hooked it up to one of those wires originally, but the light in the gauge is barely visible, even at night, since I am only pulling a max of 5.85 volts off of that source.
This is on a 1990 Honda civic.
Old Jun 30, 2004 | 08:03 AM
paybac4223's Avatar
Default Re: Wiring gauges to dimmer switch (jisu009)
Just wire them to the wires comming out of the gauge cluster and the dimmer switch will automatically control the lighting..... i have a 91 and my aftermarket tach as well as my aftermarket oil pres. and oil temp dim with my dimmer roll up and down thingy....
Old Jun 30, 2004 | 08:30 AM
jisu009's Avatar
Default Re: Wiring gauges to dimmer switch (paybac4223)
Do you know which wire you wired them to? Color? Thanks so much for the reply!
Old Jun 30, 2004 | 11:14 PM
jisu009's Avatar
Old Jul 1, 2004 | 06:37 AM
sit220's Avatar
did u try the ignition
Old Jul 1, 2004 | 06:48 AM
jisu009's Avatar
Default Re: Wiring gauges to dimmer switch (sit220)
I want it to be on the dimmer.....the ignition won't accomplish that.
Old Jul 1, 2004 | 08:00 AM
sit220's Avatar
ok but which one is the dimmer
Old Jul 1, 2004 | 03:34 PM
jisu009's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jisu009 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone know the specfic wire that I would use for power to my autometer gauges, in order to have them dim with the dimmer switch?
This is on a 1990 Honda civic.</TD></TR></TABLE>
Goobergobbler
Oct 23, 2015 06:47 AM
4DRmafia
Mar 25, 2005 12:42 PM
kmf0211
Dec 21, 2004 06:56 PM
S13 slide
Jan 12, 2002 06:28 PM
