91 crx hf questions
Old Jun 30, 2004 | 06:33 AM
tcwcrxhf's Avatar
Default 91 crx hf questions
ok im stumped I just picked up this car and when i get into the uper rpm (between 3500 and 5000 is the redline) the tranny is grinding. Is that a sign my tranny is going out or something else is wrong with it?
I dont know what tranny it is. I mean is it the same tranny as the dx or something lower like the ex?
Anyone with anything would be greatly appreciated.
Old Jun 30, 2004 | 07:01 AM
bardo's Avatar
Default Re: 91 crx hf questions (tcwcrxhf)
you have the lowest model crx..HF was the lowest model...and there was never an EX crx...or tranny for it unless your referring to the newer civics & hatchs...if the tranny is grinding its most likely shot...as far as the redline goes that is what it is...
Old Jul 6, 2004 | 11:51 PM
pArAdOxsqUArE's Avatar
my friend thought he had the same problem but his dumb *** let the brakes go badd so he was grinding his front right rotor all the time, his clutch is goin' out tooo
Old Jul 7, 2004 | 02:06 AM
Keebler's Avatar
Default Re: 91 crx hf questions (pArAdOxsqUArE)
I certainly hope someone can tell the difference in a tranny grind and bad brakes.....
As for the original question, sounds like your syncros are shot. If you are running the stock setup for engine/trans, you might want to look into doing a swap.
speed_demon018
Jan 7, 2009 05:18 PM
Bond
13
Mar 15, 2005 02:59 PM
Tex Blackwell
36
Jan 8, 2004 11:51 AM
00WhiteEKy
10
Sep 2, 2002 08:02 AM
