Crank bolt wont come off!!!
Old Jun 30, 2004 | 02:46 AM
BoostedH23Accord's Avatar
Default Crank bolt wont come off!!!
Tried everything Heated it up hit it with an impact gun. used a 24" breaker bar... used a 24" breaker bar with a pipe and Julio pushin and pullin on it and still won't come loose... Arrrrrrgh any suggestions?
Old Jun 30, 2004 | 04:44 AM
integra6650's Avatar
Default Re: Crank bolt wont come off!!! (BoostedH22Accord)
how big an impact gun?
Old Jun 30, 2004 | 06:11 AM
deSigi's Avatar
Try setting the air compressor at the high compression possible. The compression is adjustable on some models (45psi - 90psi).
Old Jun 30, 2004 | 07:09 AM
devnull's Avatar
When i first changed my Crank pulley it required a 3/4 inch impact gun with 120 psi @ 12.5 cfm to get it off. Even then it took about 2 minutes of pure hammer to get it off.
Oh yes. and heating won't help you any only make it worse. just think expanding metal in a close space.
Old Jun 30, 2004 | 07:23 AM
Default Re: (qi_doy)
dont go too much higher than what the gun is supposed to take. try a 1/2 ir titanium does 1000 lbs of torque the only bolt me or anyone i know came across that it couldn't take off was one that a 1 inch gun at 2750 couldnt remove it either it had to be burned off
Old Jun 30, 2004 | 08:49 AM
redrum eg6's Avatar
let it soak overnight with some pb blaster or other penetrating oil on it, then go to town with the impact gun.
Old Jun 30, 2004 | 09:13 AM
spark plugs.
Guest
Posts: n/a
Default Re: (redrum eg6)
penetrating oil and a big *** breaker bar will do it. i've come across man a bolt that won't budge even with an impact gun. get a breaker bar that's long enough and it'll do it.
Old Jun 30, 2004 | 11:33 AM
Crazydave's Avatar
Default Re: (spark plugs.)
I had to pump up the air compressor to 140psi to blast off my crank pully bolt with my impact wrench (which is rated at 500-ftlbs)
Old Jul 9, 2004 | 05:32 PM
It's free!!!!! We did it it took 1100ft lbs!!! Hammering away for about 3 minutes and it finally gave way. I'm gonna find a way to post pics.
You gotta see the bolt its dented from the pressure of the impact gun.
But it's finally off.
Old Jul 9, 2004 | 06:15 PM
AccordDX89's Avatar
I had the same problem. I was afraid I was gonna break the breaker bar in half. I took mine into Acura and they got it off in 5 minutes (including the time to lift and lower the car and take the wheel off) and didn't charge me anything. The bastards/
Old Feb 28, 2011 | 07:31 AM
jnmhonda's Avatar
I have a 1993 Honda Accord and I have been trying to remove the blancer bolt for 3 days now. I got the special tool to hold the blancer and I put my Impact on it for about 10 or 15 Min and didnt do nothing. I put my braker bar with a 3 ft pipe on it and twisted the Extention about 1/2 way so now the letters go around the extention. Now last night I heated the bolt and tryed it with a new extention bar and didnt bugg so I put a jack to hold the tork all night on the bolt and I just tryed to get it off again HELP HELP WHAT AM I DOING WRONG
Old Feb 28, 2011 | 08:21 AM
night's Avatar
using the pulley tool with a sears 1/2" ratchet tucked into the suspension and 3-4ft long breaker bar on the bolt I've always been able to break them loose. You have to use your body weight against the bar and it will let go. which of course means it has to be in the air.
Old Feb 28, 2011 | 02:29 PM
CRX-Kid11's Avatar
all impacts are not created equal!
Old Mar 9, 2011 | 02:24 PM
delsolintegra's Avatar
Don't be surprised. I know a guy who owns a Honda shop and he says he has an air gun rated at 1400 psi and he runs his compressor full out when he has to break one loose.
hamilton9339
Aug 18, 2011 10:51 PM
memorybox
16
Sep 28, 2006 10:00 AM
BoostedH23Accord
Jul 8, 2004 05:05 AM
slwburn
Apr 3, 2004 04:15 PM
MCP486
Apr 1, 2003 09:48 AM
