Best "Drag" Cam?
Old Nov 18, 2001 | 09:49 PM
AllMotorITR's Avatar
New User
Default Best "Drag" Cam?
I plan on tracking and auto-xing my car in the future, but not as much as probably dragging.. What would be the best cam for tracking, but more importantly, the best for drag racing? Toda Bs or Jun 3s?
Old Nov 18, 2001 | 09:59 PM
Rboosted717's Avatar
Default Re: Best "Drag" Cam? (1 FAST R)
if your gonna turbo, I'm not sure what type of cam is best. Since your going turbo, your bottom end is gonna suck, so strong cams will hurt you worse since all the power from the cams will be added to the turbo's top end. If I were you, run a street cam with the turbo. IE-spec B at most or a Jun 2. With a crazy strong cam with the turbo your car will lag and bog like hell. People will just rip on you till you get that turbo going.
Old Nov 18, 2001 | 10:03 PM
New User
Default Re: Best "Drag" Cam? (Rboosted717)
Ooops, I meant cams for an all motor setup.. i gave up on turbo.
Old Nov 18, 2001 | 10:16 PM
Stunna BEN's Avatar
Don't call it a comeback
Ive heard the JUN3 but i might be wrong!
Old Nov 18, 2001 | 10:17 PM
New User
Default Re: Best "Drag" Cam? (Big Carbon)
Yeah, see I heard that the Toda B's have more mid range torque, and the Jun 3s have higher end power, but for dragging dont you want more torque? I'm confused.
Old Nov 18, 2001 | 10:35 PM
Hybrid ctr's Avatar
JUN 3's
Old Nov 18, 2001 | 10:37 PM
ImportReview
Guest
Posts: n/a
"the record is spinning round and round, cause the record player is broken"
JUN 3's without a doubt on this planet.
Jeff
Old Nov 19, 2001 | 12:08 AM
RJL's Avatar
RJL
New User
Default Re: Best "Drag" Cam (ImportReview)
JUN IIIs' are the way to go. They are probably the best road racing cam. They do have midrange, I don't know why everyone thinks that they don't. A tech at JUn told me that these cams make hp all over the rpm range. That is why they recommend their ECU, because that ecu gives the proper fuel and ignition maps for your setup. For instance, if you run JUn IIIs on a ITR ECU, your tuned for top end performance (according to JUN). Their ECU is tuned for all around performance. The main key for these cams is compression. These need at least 11:5:1 compression, because of the huge overlap of these cams.
Old Nov 19, 2001 | 01:24 AM
comptechgsr's Avatar
Default Re: Best "Drag" Cam (Badboy01GSR)
why do you want to drag race?
are you tryin to catch up with that guy in the that SSBLUE "Type-Urrrr".....who has
toda-b's?
i hear that cat is all show...
but i heard you either need a rocket up your *** or a gsxr 1300 hayabusa turbo with nitrous to catch up....you should really look into that...
BTW, Chris, you can be the "STOPSIGN ASSASSIN" since you ran 3 stops you bitch....
i'll remain the "STOPLIGHT ASSASSIN"...
hey, check the kills forum,
i'm gonna post my first kill on YOUR *** and the JRSC'D R's ***
[Modified by comptechgsr, 4:07 AM 11/19/2001]
Old Nov 19, 2001 | 02:54 AM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: Best "Drag" Cam (comptechgsr)
BTW, Chris, you can be the "STOPSIGN ASSASIN" since you ran 3 stops you bitch....
i'll remain the "STOPLIGHT ASSASIN"...
at least he can spell "assassin"
Old Nov 19, 2001 | 03:09 AM
Default Re: Best "Drag" Cam (Dave-ROR)
<U>DOH!!!!!!</U>
...i really do not know what to say.....uhm......"just say no"!
Old Nov 19, 2001 | 04:45 AM
BoM's Avatar
BoM
VTEC killerzzz Aiiiighhhht yo!
haha!
Old Nov 19, 2001 | 04:58 AM
FAST94GSR's Avatar
New User
Default Re: Best "Drag" Cam (BoM)
QUESTION: I'm running CTR pistons with a GSR head milled 20 does anybody here think I'll run into clearance issues if i ran the JUN 3's?
Old Nov 19, 2001 | 01:38 PM
RJL's Avatar
RJL
New User
Default Re: Best "Drag" Cam (FAST94GSR)
u might, JUn does not recommend head milling with JUN III cams
V8This!
Mar 14, 2005 06:22 PM
twin rex's
May 29, 2004 01:29 PM
JunIntegra
Oct 28, 2003 10:51 AM
JBk24crx
Jun 1, 2003 09:22 PM
