about the comtech icebox...
can i just buy the comtech ice box and use my stock GSR intake arm with a k&n filter and get near the same gains as i would with the comptech short ram and icebox? dont wanna waste money on ne thing i dont need.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speedin Type R »</TD></TR><TR><TD CLASS="quote">i heard you could only use a stock arm if you have an ITR arm </TD></TR></TABLE>
Nope, you can use the stock arm on any model.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeon »</TD></TR><TR><TD CLASS="quote">i've heard of people using the stock arm but i dunno about using it with the K and n filter.</TD></TR></TABLE>
If the filter fits the stock box, then it will fit the Icebox. So you could use the K&N E-2427 drop in filter.
I used the icebox with my factory intake arm and factory filter. I suggest you use either the K&N or a factory filter, anything else isnt going to fit right in the box, nor is it going to seal properly around the box. BTW, you have to use a intake arm that works with your car(LSs can use ITRs or LS arms, GSRs have to use GSR arms).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">I used the icebox with my factory intake arm and factory filter. I suggest you use either the K&N or a factory filter, anything else isnt going to fit right in the box, nor is it going to seal properly around the box. BTW, you have to use a intake arm that works with your car(LSs can use ITRs or LS arms, GSRs have to use GSR arms). </TD></TR></TABLE>
Correct. I'm currently using the Comptech foam filter in my Icebox and the ITR OEM arm on my LS.
Which box do you have? Is it for the LS or the ITR? Did the icebox come with a filter or did you buy that seperately?
I have a GSR with a Skunk2 IM, so I will need the ITR arm, and the box for the GSR or the ITR?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redman223 »</TD></TR><TR><TD CLASS="quote">Which box do you have? Is it for the LS or the ITR? Did the icebox come with a filter or did you buy that seperately?
I have a GSR with a Skunk2 IM, so I will need the ITR arm, and the box for the GSR or the ITR?</TD></TR></TABLE>
IIRC, the box is the same for all models, but you should contact Comptech to be sure. The filter comes seperately and costs about $60 and is reusable.
I think the comptech intake arm is just bling. Im using it with stock intake rubber arm and drop in k&n filter e-2427.
comptech filter is sold separately. (50-70$ for the foam filter) EEK
if you have a skunk2 IM you'll need the itr rubber intake arm and I believe all iceboxes are universal fit for all model integras
actually the mounting brackets for the GSR and the ITR/LS are different. I know these from experience, I had to custom make my mounting brackets because the ones that came with mine were for the ITR/LS.
.water
Aug 25, 2005 11:22 PM
yellow blur
Apr 7, 2002 11:12 PM
