types of map sensors question
Old Jun 29, 2004 | 11:11 PM
handa's Avatar
Default types of map sensors question
ok i got two different (i believe) types of map sensors:
and
NOTICE one is "ps-22" and the other one is "ps-30". It seems that the "ps-22" one is for the firewall ONLY....and the "ps-30" is for the throttle body.
so are they the same? im currently using the "ps-30" one on my b16a gen2 and would like to know if there are any significant differences. Thanks!
Old Jun 29, 2004 | 11:27 PM
C uR eX's Avatar
Default Re: types of map sensors question (handa)
the ps-22 are the one te is mointed on the firewall..which some civic do have it that way..like the dx (basically the one with TB that doesn't ahve a map sensor mounted on them)
the other one ps-30 are the TB mounted map sensor...
and depending on what intake/TB you are using, it vice vesa. but either one will function the same but if you using a TB that uses a map on it then you should use the ps-30.
btw..the ps-22 should have a bracket and vaccum hose with it.
Raven2201
Jun 5, 2013 01:19 PM
Munkeyd00d
Oct 3, 2011 07:20 PM
ALL MOTOR DA
Jun 8, 2006 02:35 PM
88crxhfb16
Apr 16, 2005 05:59 PM
B18C-RnVA
Aug 18, 2002 03:01 PM
