Skunk2 Manifold power loss
Old Jun 29, 2004 | 10:19 PM
BLK99VTECR's Avatar
Default Skunk2 Manifold power loss
How much power is tended to be loss by switching to a skunk2 manfiold from a GSR manifold. Whats the best way to minimize the power loss without doing head work?.
Old Jun 29, 2004 | 11:08 PM
Downey's Avatar
Default Re: Skunk2 Manifold power loss (BLK99VTECR)
here is my friends GSR before and after mods.
Before: AEM CAI, 7.5 flywheel, Nothing else. Stock everything else!!
After: AEM CAI
64mm throttle body
Skunk2 intake mani (64mm inlet)
Hondata manifold gasket
Portflow valve springs/retainers
Skunk2 stage 1 cams and cam gears
B&M FPR
RC440 Injectors
Hondata S200 Tuned by Lawrence at DSR
JDM 4-1 header
Stock JDM R cat (restrictive!)
Stock JDM R exhaust and muffler (restrictive, but sleeper!)
you can see where he actually lost mid range power, which i think is due the Skunk2 single runner style manifold. you can see he only lost 5-7whp from 4500-5500rpm. But the gains up top are well worth the mid range dip. Im sure with a freeier flowing cat and exhaust and maybe even a short ram intake the dip would dissapear and be smoother. but i still think the gsr has better mid range power.
Old Jun 30, 2004 | 12:36 AM
TimoneX's Avatar
New User
Default Re: Skunk2 Manifold power loss (Downey)
I think that result is fairly typical. My GSR experienced a similar dip with the skunk2 manifold and also better breathing in the top end, though I made many changes at the same time so I cannot attest to the isolated effects of the manifold swap. I think it's a good mod if you're going to wind the motor up with regularity.
Old Jun 30, 2004 | 05:21 AM
BLK99VTECR's Avatar
Well I already have I/H/E/CAT/FPR/VAFC. I was just going to get the manifold now because I need to get a chipped ECU and I was told that if i get on on the STOCK manifold that it would cause me a loss of power due to the secondaries being left open.
Old Jun 30, 2004 | 03:46 PM
TimoneX's Avatar
New User
Default Re: (BLK99VTECR)
Just another reason to go for the skunk2 IM if/when you can afford it. It's a good mod and the inability of the P28 to control the secondary runners on the stock manifold just gives you another reason(excuse) to go with the aftermarket manifold. I was faced with the same situation when I switched ECUs to a hondata modded P28. I tied the secondary runners on the stock manifold open until I got around to installing the skunk2 IM.
Old Jun 30, 2004 | 09:44 PM
GSRswapandslow.
Guest
Posts: n/a
the skunk2 is not designed correctly, why would you want to put something like that on your car?
save up some more money and get a JG sheetmetal
Old Jun 30, 2004 | 10:46 PM
ToddZILLAinLA's Avatar
Default Re: (GSRswapandslow.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRswapandslow. &raquo;</TD></TR><TR><TD CLASS="quote">the skunk2 is not designed correctly, why would you want to put something like that on your car?
save up some more money and get a JG sheetmetal</TD></TR></TABLE>
dude thats some really bad advice, I have the jg sheetmetal one my self that thing is huge put that on his set up he is going to have a big hp loss the JG IM loves big motors and high RPM's
Old Jul 1, 2004 | 07:26 AM
GSRswapandslow.
Guest
Posts: n/a
he'd lose a LITTLE bottom end, but he'd gain a LOT of top end. it's worth it.
if you're JG is for a b16 head, willing to sell it?
Old Jul 1, 2004 | 09:35 AM
user 996328629's Avatar
i had a JG manifold on my gsr with bolt ons and i felt a HUGE loss from 0-7000 rpms..than 7000-8000 it felt the same..
Old Jul 1, 2004 | 10:18 AM
itbtype-r's Avatar
check out AN-R site, Think they still have dyno figures . gained lil over 8whp on stock gsr and took vtec dip out.....
Old Jul 1, 2004 | 11:49 AM
GSRswapandslow.
Guest
Posts: n/a
Default Re: (Swags04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Swags04 &raquo;</TD></TR><TR><TD CLASS="quote">i had a JG manifold on my gsr with bolt ons and i felt a HUGE loss from 0-7000 rpms..than 7000-8000 it felt the same.. </TD></TR></TABLE>
i doubt you really had much of a loss. ive seen many cars dyno a little less...but all of them ran faster
Old Jul 1, 2004 | 11:22 PM
bottom end sucks but **** bottom end im not road racing and when i launch my car im around 72rpms, sounds funny cause vtec is just going bop,bop,bop,bop,bop with the jg cams fucken things need full throatle for vtec to open up but the jg IM loves that ****
lazii_boi08
May 2, 2011 10:49 AM
wegotmorrison
Aug 31, 2007 04:13 PM
vtec8k
Jan 18, 2005 02:26 AM
stivic
Dec 4, 2004 03:22 PM
BLK99VTECR
Jul 15, 2004 11:27 AM
