Engine Cleaning
Old Jun 29, 2004 | 08:47 PM
Muckman's Avatar
Moderator in Chief
Default Engine Cleaning
Had my block sleeved by Benson. While it was there it was hot tanked 3 or 4 times. Now Im assembling it. However it still looks like ****. The block has like corrosion all over it. The aluninum has a dingy color to it. My block is only 4 years old but it must be the NY winters and salt have taken its toll.
How can I make it look clean and new like everyone elses built up bottom ends? Ive tried a scotch brite pad and fine sand paper. Its not greasy so Simple Green has no affect.
Old Jun 29, 2004 | 09:20 PM
sneakypete's Avatar
Default Re: Engine Cleaning (Muckman)
Your best bet would be to paint the block with some high temp engine enamel. A gray color would look good.
Old Jun 29, 2004 | 09:51 PM
Muckman's Avatar
Moderator in Chief
Default Re: Engine Cleaning (sneakypete)
I was thinking that would be my last resort. My local engine shop says try muriatic acid. But I read on here that it disintegrates aluminum and leaves it dull and gray looking.
Basically I just need to remove the oxidation. What about having it sand blasted?
crip
Jan 25, 2010 07:33 AM
slimjimming6688
Appearance Build Threads
Dec 25, 2008 10:30 AM
HCivicSi23
Paint and Body
Apr 6, 2008 07:00 PM
Muckman
Aug 4, 2006 01:56 PM
92DSeries
10
Jan 15, 2004 04:01 AM
