removal of an AC piece???
Old Jun 29, 2004 | 05:59 PM
schtozo's Avatar
Default removal of an AC piece???
the big **** that is in the middle of the car behind the middle vents and beside the avaporator. can i remove that big thing with out removing the dash or i have to???
if it is not necessary to remove the dash, can any body help me out with this?? how many screws? where?
thabks in advance.
Old Jul 1, 2004 | 02:51 AM
menkio's Avatar
Default Re: Re: (b18cpowered)
are you talking about the heater/core ??
Cuase if you want to remove that, just take out your dash. It's just common sense, work threw the dash remove everythng you see. Remove all thoose vents, remove the GIANT/heavy heatercore. You can also remove your psgnr airbag at this time as well. You will also need to loop your coolant lines
Old Jul 1, 2004 | 03:21 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: Re: (DewMota)
man.. i had a BITCH of a time removing mine w/o taking off the dash... there were several screws and clips that i could not see.. its cluttered doing that stuff from underneith... maybe its just me..
Old Jul 1, 2004 | 03:39 AM
menkio's Avatar
Default Re: Re: (kKdARIAN)
that and it would be half-assed, you need to taske the dash off for the vents. No sense in leaving extra weight
Old Jul 1, 2004 | 03:50 AM
kKdARIAN's Avatar
Vice President/CEO
very much half assed... i ended up taking off the dash... it was much easier.. i forgot to mention that i did that.
Old Jun 24, 2007 | 11:54 PM
97BlackDX's Avatar
On a car with A/C do you need to remove the evaporator (i.e. purge the a/c system too) to remove the core as the Helm's says to or can you get by with "just" removing the dash?
dns92civhatchcx
Feb 5, 2013 06:43 PM
y2kferari
Mar 16, 2007 02:12 PM
neilff
Apr 24, 2003 09:46 PM
charjacq
10
Feb 16, 2002 07:23 AM
