engine not firing right
hi right to the point my engines a b16 vtec the problem i have is the car wont stay started and is only firing on the 4th cylinder and making a knocking noise then shuts down the ecu was blinking the code for the water temp sensor i fixed that i also replaced the spark plugs,rotor,dist cap,wirers,the only thing i found is the knocksenser conection was broke i havent fixed this yet but could this be the problem if not any info would be great thank you
Gavin G
20
Aug 2, 2014 05:25 AM
DaGlitch
Feb 10, 2008 06:19 PM
TheIceMan
12
Dec 23, 2005 04:08 AM
se93
Oct 7, 2002 07:00 PM
