Strange Voltage problem... Think its Hondata related...
Old Jun 29, 2004 | 04:22 PM
ScrapinSi's Avatar
Default Strange Voltage problem... Think its Hondata related...
Here is my setup...
2000 Civic Si
b16a2
Custom Kit
Hondata S200 w/ boost, datalogging, & rom editor w/ p28 ECU
Boomslang Xover Harness
I just put in my digital voltmeter, and I began noticing something... While on throttle at any percentage, voltage drops, sometimes as low as 12.0 volts. When I am on Decel in gear, the voltage quickly climbs back up, but when I hit the throttle to any level, the voltage begins to drop.
Also, I notice that my volt gauge reads anywhere from .3 to .7 volts lower than my blitz turbo timer... Both are tapped into the same wire, directly to the ignition. I am going to solve that problem by tapping my multimeter into the same wire and see which is more accurate.
Should I disconnect the ALTC wire from the ECU Harness? Will this throw a CEL? Will this cause over/under voltages?
Old Jun 29, 2004 | 04:42 PM
ladysman's Avatar
Default Re: Strange Voltage problem... Think its Hondata related... (ScrapinSi)
Disable ELD in the software.
Old Jun 30, 2004 | 03:30 AM
ScrapinSi's Avatar
Default Re: Strange Voltage problem... Think its Hondata related... (ladysman)
you sure? Thats it? Damn... Time to get ahold of hondata and reinstall the rom editor software... LOL
Old Jun 30, 2004 | 04:28 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScrapinSi &raquo;</TD></TR><TR><TD CLASS="quote">you sure? Thats it? Damn... Time to get ahold of hondata and reinstall the rom editor software... LOL </TD></TR></TABLE>
With similar problems I have had with Hondata systems, this fixed it.
Good luck.
Old Jun 30, 2004 | 05:40 AM
ScrapinSi's Avatar
Cool... I'll give it a whirl... It was weird... this morning it didnt do it the first time i drove it, but the 2nd time i drove it, it did...
Old Jun 30, 2004 | 05:46 AM
EE_Chris's Avatar
Alt-C wire - just unpin it and see what happens. This has been the fix to many people using Hondata.
ryguy2588
Aug 19, 2011 12:18 PM
danny98r
Jan 16, 2005 07:51 AM
ebpcivicsi1234
Jan 14, 2005 04:45 PM
vtekthis
Nov 16, 2003 10:12 PM
