need some info about short air intakes
Old Jun 29, 2004 | 03:48 PM
krack's Avatar
Default need some info about short air intakes
man i picked up another tube that will attach to the one i allready have and run down into my fender ,is there a certain way i should run this like at a certain angle or without a filter and is this called a cold air intake now????
sorry if i seem not to know **** but atleast i ask and not try to pertend i know everything like some other dumb ***** lol
thank guys
Old Jun 29, 2004 | 03:56 PM
paybac4223's Avatar
Default Re: need some info about short air intakes (KRIZACK)
please use a filter... one rock will ROCK your world..... just put a k&n on the first tube and call it a day dont worry about the cai right now....
Old Jun 30, 2004 | 11:48 AM
krack's Avatar
SO I TAKE IT THAT A COLD AIR INTAKE DOES NOT HAVE A FILTER ON THE END
Old Jun 30, 2004 | 01:58 PM
Daedus's Avatar
Default Re: (KRIZACK)
No, a cold air intake does have a filter on the end. He's just saying that if you didn't have a filter you could inhale rocks and ruin your motor.
Old Jun 30, 2004 | 02:20 PM
EliteCivicX's Avatar
air intake requires the tube + filter and it sits higher than the cold air intake.
cold air intake requires tube + filter as well, goes down lower to ground to recieve "colder" air.
Old Jul 1, 2004 | 09:31 AM
krack's Avatar
well it looks to me like this filter will be about just under 2 inchs from the bottom of the bumper
i was tring to cut out a pc of thin filter screen to put in the middle where the 2 pipes connect..like a mesh screen so ill have no filter on the end
what trips me out is that when the intake manifold opens that it could really have the suction power to pull air up that long *** tube
Modified by KRIZACK at 11:13 AM 7/1/2004
Old Jul 1, 2004 | 12:20 PM
paybac4223's Avatar
thats like saying you cant believe that your lungs have the power to hit a 4 foot bong or saying that you cant belive that you can suck up a slurpee through an extra long straw....lol
SpyderZEX's Avatar
Yes the engine does have enough suction to pull the air, along with plenty of dirt if you do not use a filter. The stock intake is almost twice as long as the runner for a cold air intake.
DO NOT GO FILTERLESS!!!
Old Jul 1, 2004 | 02:23 PM
krack's Avatar
oh ya i can hit the 4 footer, its the blunts that make me choke
Old Jul 1, 2004 | 07:47 PM
suspendedHatch's Avatar
dont use a homemade filter. don't worry about the filter hurting your power, it wont. just get an apexi or K&N. do you understand that particles smaller than you can see are lining up your cylinder walls and scratching the hell out of your engine?
intake manifolds dont open. well, GSR and prelude ones do, but that's different.
Valenciabrihh
16
May 10, 2015 11:16 AM
Canadian_EF
Apr 20, 2009 09:26 AM
984.6gt
Mar 4, 2004 05:13 PM
alias 33
22
Jan 18, 2004 07:22 PM
