2 nitrous bottles??
Old Jun 29, 2004 | 03:22 PM
londa hover's Avatar
Default 2 nitrous bottles??
what are the pros and cons of having 2 n2o bottles? will it help keep more pressure? like if both bottles are half empty and the pressure on each bottle is at 600 will it make the pressure in the line be 600? or would it be higher?
Old Jul 1, 2004 | 02:38 PM
Default Re: 2 nitrous bottles?? (londa hover)
Old Jul 1, 2004 | 02:53 PM
MooreBoost's Avatar
I guess youll have to fill half as much. And that would keep you at a higher bottle pressure, more power, for longer.
Old Jul 1, 2004 | 04:41 PM
J337_UNIT's Avatar
Default Re: 2 nitrous bottles?? (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">I guess youll have to fill half as much. And that would keep you at a higher bottle pressure, more power, for longer.</TD></TR></TABLE>
no.
alot of people who have 2 bottles will just have one open at a time. when one runs out or gets low, they close that one and open the fresh one. Opening both at the same time wont increase pressure if they are both full... however , if one is running low and is let open, and the other fuller one gets opened, its going to dump alot of its pressure into the other bottle, if they are hooked up together, which is a waste.
Old Jul 1, 2004 | 04:47 PM
Suprdave's Avatar
Just run 1, 15lb Bottle.
Old Jul 1, 2004 | 04:51 PM
CivicSiRracer69's Avatar
Default Re: 2 nitrous bottles?? (Suprdave)
use the Zex maximizer kit and run auto openers on both bottles.
Old Jul 1, 2004 | 06:49 PM
SprayinCX's Avatar
Default Re: 2 nitrous bottles?? (CivicSiRracer69)
well i had two for the reason of when one gets low you can shut it off and go to the other. Also you have to remember when you are tuning your nitrous kit you need to keep your bottle pressure consistent. cause if you have for nitrous then fuel, well we all know what will happen. If you more the other way around will result in loss of power and such. i usually tune mine around 900psi. then i either heat the bottle up or cool it down before every pass.
kornerk12
Apr 8, 2009 05:06 PM
Layziebtnh055
Aug 8, 2005 12:47 PM
SpyLude92
Mar 25, 2004 02:59 PM
2k1 GSR
Oct 27, 2003 08:06 PM
White97Teg
Apr 12, 2002 11:43 AM
