how to tell jun cams for stock?
Old Nov 18, 2001 | 06:24 PM
mikeyz's Avatar
Default how to tell jun cams for stock?
im buying some cams off a guy in tenn. and hes sending me some jun 3 cams, was wondering if there is any way to tell if they are real? thanks mikey
Old Nov 18, 2001 | 06:31 PM
RJL's Avatar
RJL
New User
Default Re: how to tell jun cams for stock? (mikeyz)
yeah huge *** VTEC lobe
Old Nov 18, 2001 | 07:58 PM
Mike K's Avatar
Default Re: how to tell jun cams for stock? (Badboy01GSR)
yep. for sure. VTEC lobes on the 3's are enormous compared to the low lobes
Old Nov 18, 2001 | 08:14 PM
mikeyz's Avatar
Default Re: how to tell jun cams for stock? (Mike K)
any pics of them? thanks guys, just trying to not get ripped off
Old Nov 18, 2001 | 09:28 PM
mikeyz's Avatar
ok quick question what lobe is the vtec lobe? from left to right
MackSpeed-616's Avatar
the middle one bro
Old Nov 18, 2001 | 09:40 PM
BoM's Avatar
BoM
Default Re: how to tell jun cams for stock? (TurboR616)
how much are u buying them for?
that can tell u if its a rip too...
Old Nov 18, 2001 | 09:41 PM
mikeyz's Avatar
Default Re: how to tell jun cams for stock? (BoM)
750 used.
Old Nov 18, 2001 | 10:56 PM
Toda Party's Avatar
On the shaft closest to the viewer (on the bottom of the picture) the lobes are:
primary vtec secondary
Old Nov 18, 2001 | 11:10 PM
mikeyz's Avatar
OK one last question thanks guys for bearing with me. What do you mean by
is it taller? wider? hows it huge? THANKS!
[Modified by mikeyz, 8:10 AM 11/19/2001]
Old Nov 18, 2001 | 11:13 PM
Toda Party's Avatar
taller
[Modified by Toda Party, 8:15 AM 11/19/2001]
Old Nov 19, 2001 | 02:13 AM
GZR4DR's Avatar
Default Re: how to tell jun cams for stock? (Toda Party)
It will also be engraved on the side of the cam. Something like HC1003 or something. i know its similar to that.
Old Nov 19, 2001 | 04:42 AM
RJL's Avatar
RJL
New User
Default Re: how to tell jun cams for stock? (GZR4DR)
dude u seriously can't miss the VTEC lobe, its the middle lobe. It's F'n huge. its got an extreme ramp angle.
Old Nov 19, 2001 | 04:56 AM
FAST94GSR's Avatar
New User
badboy we essentially have the same setup, what times are you running and what kind of power are you putting down.
QUESTION: I'm running CTR pistons with a GSR head milled 20 does anybody here think I'll run into clearance issues if i ran the JUN 3's?
Old Nov 19, 2001 | 01:46 PM
RJL's Avatar
RJL
New User
Default Re: how to tell jun cams for stock? (FAST94GSR)
my pistons are going in this week. Ive been hitting 14.7 on a GSR bottom end on street tires. I need compression, the GSR compression isnt sufficient enough, acutally bleeding off compression because of the over lap. The thing is with your head being milled, u might have clearance issues with the CTR pistons. Contact JUN USA, they should have a definite answer. I Know with CTRs and JUN III clearance is close, as long as u leave the cams at 0,0. How much of a difference did the CTRs' do in your car?
zamrioo2
May 17, 2007 09:03 AM
NBPdEeCeE
Feb 19, 2007 07:59 AM
^AnDre^
47
Jan 30, 2005 01:04 AM
tecnic1
Mar 5, 2002 09:07 PM
Leo95SE
Aug 10, 2001 01:26 PM
