How do u tell the Difference between these two?????
crank pulley, and the alt belts.
jdm gsr alt part# xxxx-p72-xxx
jdm r alt. belt part# xxxx-p73-xxx
wil only work for jdm motors. usdm r and usdm gsr both have the same crank pulley and alt. belt.
btw the difference is that jdm R has a smaller alt pulley, so the belts need to be shorter. ofcourse they could switch the pulley on you, but just look at the pulley bolts to se if they have been off before.
black2001gsr
Feb 19, 2003 08:55 PM
