How do u tell the Difference between these two?????
Old Jun 29, 2004 | 02:53 PM
DeDonDeRosa's Avatar
Default How do u tell the Difference between these two?????
how do you tell the difference between a JDM GSR Block and a JDM ITR block
cause they both say B18C
Old Jun 29, 2004 | 03:06 PM
..::91TEG-G2::..'s Avatar
Default Re: How do u tell the Difference between these two????? (DeDonDeRosa)
hmm, if there is the vin number on it somewhere, do a car fax and it might tell you..
and usdm itr's say b18c5 huh?
Old Jun 29, 2004 | 03:09 PM
Default Re: How do u tell the Difference between these two????? (..::91TEG-G2::..)
these are the jdm blocks not the us blocks
Old Jun 29, 2004 | 03:12 PM
_noname_'s Avatar
take a look at the pistons!
Old Jun 29, 2004 | 03:20 PM
esponet's Avatar
crank pulley, and the alt belts.
jdm gsr alt part# xxxx-p72-xxx
jdm r alt. belt part# xxxx-p73-xxx
wil only work for jdm motors. usdm r and usdm gsr both have the same crank pulley and alt. belt.
btw the difference is that jdm R has a smaller alt pulley, so the belts need to be shorter. ofcourse they could switch the pulley on you, but just look at the pulley bolts to se if they have been off before.
Old Jun 29, 2004 | 03:35 PM
Default Re: (esponet)
there are no markings on the block or anything like that
one more thing which head is a pr3-3 is that JDM ITR?
Old Jun 29, 2004 | 04:11 PM
AK94GSR's Avatar
Default Re: (DeDonDeRosa)
yes it could either be a b16 head or itr
since that is the code for both of them usually
eddie7978
Dec 7, 2017 02:57 AM
maxogsr
Jun 30, 2011 02:56 PM
Muckman
Apr 28, 2007 06:59 AM
gsrintegra1976
Nov 13, 2003 08:13 AM
black2001gsr
Feb 19, 2003 08:55 PM
