Running rich/ Really bad MPG
Old Jun 29, 2004 | 07:23 AM
LilGreenMachine's Avatar
Default Running rich/ Really bad MPG
Hi guys I'm new to Hondas, and need some help. I bought a car w/ a B16 in it. It has about 50K miles on it. If I rev the engine it smells really rich and I'm only getting about 190 miles to a tank.
Would a full tune-up fix this problem?
What all goes into it? Like a timing belt, plugs, etc. What else?
Old Jun 29, 2004 | 07:54 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: Running rich/ Really bad MPG (LilGreenMachine)
Might as well do a good tune up, Air filter, Distributor cap / rotor, plugs...
Old Jun 29, 2004 | 07:56 AM
Default Re: Running rich/ Really bad MPG (LSVTEC 91 Civic)
Doing a tune-up ought to clean up any timing issues which might be running it rich?
Old Jun 29, 2004 | 08:08 AM
crx_88_si's Avatar
nah.. replace the o2 sensor's, air and fuel filters, plugs, wires, cap, rotor, make sure it's correctly timed.
Also.. how do u drive it?
Old Jun 29, 2004 | 08:21 AM
Default Re: (crx_88_si)
I have a B16 SiR w/ 2 O2 sensors. Where should I get those from?
DO I need to replace the plug wires? They are NGK wires.
I do run it somewhat hard, but I should be getting better MPG than that right? Plus the rich smell. I only bought the car a few months ago. I've changed the oil and what not. I need to do this tune-up though. I don't know what condition the timing belt is in.
Old Jun 29, 2004 | 08:33 AM
crx_88_si's Avatar
does the CEL (check engine light) turn on for 1 sec when you prime the fuel pump b4 starting?
How does the car idle? any back firing? stumbles?
Old Jun 29, 2004 | 08:40 AM
I don't know about the CEL, I'll have to check. I don't think so. I had to fix my FITV, so my idle was giving me problems. Then it was fine for a while, but if I put on my AC while stopped, it seems to want to kill it. It won't, but it bogs a little.
Plus my idle has been acting kind of weird, like keeping it below 1K, then it might search a little, then it's fine. I pulled of my TBI and cleaned it all. Fixed the ringcap in the FITV. Burped the system. I had to turn my idle adjustment screw all the wy down to get it to idle around 800 RPMs.
What's up w/ my car?
Old Jun 29, 2004 | 08:48 AM
crx_88_si's Avatar
Default Re: (LilGreenMachine)
I think you are doing your idle settings incorrectly.
here ya go ... in steps.
1. Warm car up to operating temperature.
2. Make sure NO accessories are on, Stereo, Heater/ac, lights, even the rad fan
3. Unplug the IACV.
4. Set the idle via the Idle screw on the TB to around 600rpm
5. Shut car off, plug the IACV back in.
6. Pull hazard fuse for 30 sec to reset ecu
7. Start the car and let it idle until the coolin fan comes on again.
Old Jun 29, 2004 | 09:06 AM
Sweet. I'll try that when I get home. This won't fix my richness problem will it? So adjust the idle properly, and do a full tune up, and time it, and that should correct most of my problems?
What about the 2 O2 sensors? And the plug wires?
Old Jun 29, 2004 | 09:12 AM
crx_88_si's Avatar
well check to see if the check engine light comes on for 1 sec when you first put your key in and prime the fuel pump. If it doesnt i bet some1 pulled the bulb out to hide the light and you have some codes.
Old Jun 29, 2004 | 09:13 AM
I know my CEL works if that's what you meant. when I fixed my FITV, it threw a code because I forgot to plug it back in. 14 I think. The CEL was working then.
Old Jun 29, 2004 | 09:15 AM
crx_88_si's Avatar
ok good.when driving around dont rev past 4k if u can help it. You'd be surprised how much throttle angle/position eats gas.
remember, part throttle = 30psi fuel, WOT = 40psi. thats a 33% increase in pressure!
Old Jun 29, 2004 | 09:55 AM
Rywire's Avatar
If your 02's are switched it will cause 2 of the cyl to be rich, and the other 2 to be lean. Make sure yours are not switched, also, how are they ran? Just like stock? Does your car hesitate at partial throttle?
The reason being is that many people who are rich with b16's have there 02's ran incorrectly. Just my 2 cents. Ryan
Old Jun 29, 2004 | 10:18 AM
Default Re: (droppedcrxsi)
How can I tell? Wouldn't I be throwing a code? My car seems to get up fine even at half-throttle.
One's green, one's milky white. They're hooked up the same as when I bought the car.
Old Jun 29, 2004 | 10:42 AM
crx_88_si's Avatar
obd0 b16 o2 setup's..
ecu 2nd o2 location
aftermarket header
jdm b16a1 header
Old Jun 29, 2004 | 12:26 PM
I know I can use a 99 Si timing belt, what about the cap and rotor?
Old Jun 29, 2004 | 12:55 PM
rsbad454's Avatar
use a 90-91 integra cap and rotor...you can also use a 94 Del Sol and 92-93 GSR VTec belt.
Old Jun 29, 2004 | 01:07 PM
Default Re: (rsbad454)
Wasn't the 92-93 GSR a B17?
Old Jun 29, 2004 | 03:25 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LilGreenMachine &raquo;</TD></TR><TR><TD CLASS="quote">Wasn't the 92-93 GSR a B17?</TD></TR></TABLE>
Yep...same belt tho. B17a has PR3 stampings all over it.
Stevo F
Jul 6, 2014 04:25 PM
Brent1
23
Dec 31, 2005 03:01 PM
jjaskula1
Nov 27, 2005 04:55 PM
90-CRXSi
Jul 24, 2003 08:32 PM
91 Civic B16
May 19, 2002 08:57 PM
