steering hose...disconnect
Old Jun 29, 2004 | 01:55 AM
mattcalica's Avatar
Default steering hose...disconnect
alright, so this is how i've been running my car. i took out the power steering pump. i looped the two small lines, but the big high pressure line that runs to the top of the pump, i just left that alone. so its not capped, not connected to anything. my steering feels fine, almost as simple as the power steering, but i was wondering if i could be drying out the rack...i figure that there has to be fluid still left in the rack, enough to lubricate it, because i dont think all of it shot up through the hose. what are your guys thoughts on this?
Old Jun 29, 2004 | 03:37 PM
mattcalica's Avatar
Default Re: steering hose...disconnect (mattcalica)
ttt
Old Jun 29, 2004 | 10:21 PM
mattcalica's Avatar
bump
Old Jun 29, 2004 | 11:10 PM
Two_K Si's Avatar
You should just remove all the hard lines and loop the in and out holes on the rack. People say it is a god idea to leave some fluid in the rack for seals and such, but the rack does not get lubricated be the ps fluid. The steering gears do not come in contact with ps fluid, they are lubed by grease. If anything, you should just cap off the open line so no debris can get it.
oneheadlight
Nov 22, 2015 05:31 AM
732xghost
Nov 5, 2009 01:09 PM
h22a193
Jun 12, 2004 11:04 PM
