engine installing about sensors
i have a problem im installing an 95 jdm gsr engine into a 2000 civic si and i can detepick witch sensor of my harnis for the civic goes into the engine if any one could help me it would be very helpfull u can email at wutang68@optonline.net or im me at mafiakid566.
yes, a 95 jdm gsr motor can definately go into a 99-00 civic si...i would call hasport & get some mounts. do an obd2>obd1 conversion & use a hondata ecu
Modified by roastbeefrichie at 3:13 PM 6/15/2007
...please check your local laws regarding dropping your 95 gsr motor in your 99-00 civic si. if i am not mistaken, the laws in my state stipulate that you can drop a motor from the same year as your car is titled or newer. in other words, my state will not allow me to swap a motor which is older than your shell due to emmission restrictions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roastbeefrichie »</TD></TR><TR><TD CLASS="quote">...please check your local laws regarding dropping your 95 gsr motor in your 99-00 civic si. if i am not mistaken, the laws in my state stipulate that you can drop a motor from the same year as your car is titled or newer. in other words, my state will not allow me to swap a motor which is older than your shell due to emmission restrictions. </TD></TR></TABLE>
Yeah, some states require that the engine be the same year or newer than the year of the vehicle you're putting it in.
same thing as switching from obd2- obd1. States dont allow it because of emissions standards.
flippedoutasian
18
Jan 5, 2004 10:02 PM
