new distributor help
Old Jun 28, 2004 | 08:01 PM
sanjiyan69's Avatar
Default new distributor help
I just purchased a new dizzy from distributor king. I have a 1990 civic wagon with b16a swap (obd0). I know I plugged in the wires correctly... Is there anything else I am missing because the car wouldn't start...?
Thanks for the help.
Wayne
Old Jun 29, 2004 | 12:49 AM
Los.'s Avatar
Default Re: new distributor help (sanjiyan69)
is there any spark? does the motor turn over at all? what happens when u turn the key?
Old Jun 29, 2004 | 04:17 AM
sanjiyan69's Avatar
Default Re: new distributor help (crxkid88Sir)
when I turn the key, the motor just keeps cranking and cranking....but doesn't start
Old Jun 29, 2004 | 06:22 AM
jdmcraze's Avatar
i have the same problem hope someone can help
Old Jun 29, 2004 | 07:25 AM
APEX CRX's Avatar
so are you getting spark? do you hear the fuel pump or smell gas?
Old Jun 29, 2004 | 08:58 AM
bluetiddlywinks's Avatar
I have a 91 hatch with a B16A OBD0 and we changed the cap and rotor with one for a 90 integra to have it match correctly, make sure you are getting that part and not one intended for the US 99-00 B16A.
Old Jun 29, 2004 | 09:00 AM
EL Vap133's Avatar
Default Re: new distributor help (bluetiddlywinks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluetiddlywinks &raquo;</TD></TR><TR><TD CLASS="quote">I have a 91 hatch with a B16A OBD0 and we changed the cap and rotor with one for a 90 integra to have it match correctly, make sure you are getting that part and not one intended for the US 99-00 B16A.</TD></TR></TABLE>
Also, make sure the rotor didn't fall off.
Old Jun 29, 2004 | 05:42 PM
sanjiyan69's Avatar
I specifically asked for the jdm 1st gen b16 dizzy...I double checked it too
Old Jun 29, 2004 | 05:43 PM
sanjiyan69's Avatar
Default Re: new distributor help (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">
Also, make sure the rotor didn't fall off. </TD></TR></TABLE>
whoa rotor fall off?
LightWeight(J)
Jun 8, 2009 06:31 PM
VTECengaged
Dec 14, 2006 11:02 AM
97hatchb16
12
Sep 6, 2006 08:05 PM
billybong91DA
Jul 6, 2004 08:09 AM
CHRIS 1.8
17
Feb 24, 2003 10:10 PM
