b17 block
Old Jun 28, 2004 | 06:31 PM
hb4u2nv's Avatar
Default b17 block
would a b17 block fit on a b16 head?
Old Jun 28, 2004 | 06:50 PM
JDMotive's Avatar
Default Re: b17 block (hb4u2nv)
A b16a head would fit on a b17a block..theyre are exactly the same.The blocks are also the same.The main difference is the crank has a few more mm's of stroker and slightly shorter rods.
Old Jun 28, 2004 | 09:46 PM
PHiZ's Avatar
Default Re: b17 block (JDMotive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMotive &raquo;</TD></TR><TR><TD CLASS="quote">A b16a head would fit on a b17a block..theyre are exactly the same.The blocks are also the same.The main difference is the crank has a few more mm's of stroker and slightly shorter rods.</TD></TR></TABLE>
I'm pretty sure the cams are different also.
-PHiZ
Old Jun 28, 2004 | 10:48 PM
JDMotive's Avatar
Default Re: b17 block (PHiZ)
Yeah..well screw you too! j/k
JDM96SpecCTR
Aug 25, 2005 04:43 AM
Honda Sport
Apr 1, 2003 02:26 PM
FLIPboi
Mar 10, 2003 08:16 PM
