12.5.1 compression b20vtec done but have a few ?
will post the setup and pics later on tomorrow.
well i just finished it up, but i have a few ?'s for the guru's. on the stock crx factory wiring harness. tere is a plug with a rubber boot around it and it has two pins in it. looks to me like it's the coolant temp fan switch connector for the radiator fan right? i am going to need to wire that up to the new b20vtec coolant sensor next to the thermostat housing right? also i also need to wire up the knock sensor, vtec oil pressure, and the vtec solenoid. where can i get this info.
Ya, lenghten the wires, and sodder them to the new style plug on the thermostat housing. What obd are you? It depends on what 0bd0-1 harness you used, if you are obd1. Let us know. Ryan
Layziebtnh055
11
Mar 23, 2005 06:44 PM
tvrsir
Jun 28, 2004 11:21 PM
